Hydrostatic Fluid Temperature?
20 replies to this topic
#16 Paulgo OFFLINE
Paulgo
  • 694 Thanks
  • 462 posts
Posted March 29, 2016 - 09:19 PM
Strap on sensor would be easier I figure. May not give exact fluid temperature, but would let you know if it's heating up. That would also keep the wire more to the top so it won't get tangled up in any thing.
Noel
That's what I want, a sensor that straps onto the suction line between gearbox/reservoir and charge pump. Could wrap a little foam around it. Have looked, but no luck so far. All I am finding are normal probes meant for immersion in the oil. Might be able to make one of those work...
  • propane1 said thank you
#17 propane1 ONLINE
propane1
  • 8,479 Thanks
  • 4,040 posts
Posted March 30, 2016 - 04:32 AM
Use one of those, slide it into a piece of copper tubing, then strap the copper to where you want, silicone the ends of copper, then put the foam over it.
Noel
  • Paulgo said thank you
#18 John Arsenault ONLINE
John Arsenault
  • 2,407 Thanks
  • 1,158 posts
Posted March 30, 2016 - 07:44 AM
Can you use the hydro ports?
#19 Paulgo OFFLINE
Paulgo
  • 694 Thanks
  • 462 posts
Posted March 30, 2016 - 07:54 AM
I don't see how?
#20 olds45512 OFFLINE
olds45512
  • 1,338 Thanks
  • 677 posts
Posted March 30, 2016 - 11:26 AM
the sensor would have to be installed in a reservoir, I don't think it would handle the psi of being in the port.
#21 warrior120 OFFLINE
warrior120
  • 56 Thanks
  • 74 posts
Posted March 30, 2016 - 07:25 PM
the only negative i see to that idea is that it would put the wire and the sending unit down low where it could get damaged.
You could build a housing around the port and sending wire
