Hydrostatic Fluid Temperature?
20 replies to this topic
#1 Paulgo OFFLINE
Paulgo
  • 689 Thanks
  • 461 posts
Posted March 29, 2016 - 01:37 PM
I want to monitor the hydraulic fluid temperature in my 40 year old GT's. Have seen refrigeration setups where a probe clamped onto a pipe and then was connected to a meter. There should be something similar that I can use to watch the temp of the fluid in the suction tube between the reservoir and charge pump. Anybody done something along these lines?  Paul
#2 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted March 29, 2016 - 01:49 PM
Many Digital multimeters have a tempature probe just for this. Mine has a 6' lead, This could be taped to the line you want to measure.
  • Paulgo said thank you
#3 Paulgo OFFLINE
Paulgo
  • 689 Thanks
  • 461 posts
Posted March 29, 2016 - 02:00 PM
That could work for random checks. Hoping to add a permanently mounted gauge to each of my GT's.
#4 olds45512 OFFLINE
olds45512
  • 1,338 Thanks
  • 677 posts
Posted March 29, 2016 - 02:38 PM
You could buy an oil temperature gauge and drill a hole and thread it for the sensor, then you just need to figure out where you want to mount the quage.
  • TomLGT195, Bill 76 and Paulgo have said thanks
#5 James Bosma ONLINE
James Bosma
  • 1,156 Thanks
  • 585 posts
Posted March 29, 2016 - 04:21 PM
Would a water temp gauge work, The ones with the probe on the end, Could tape probe tight to pipe to read temp of the pipe, or a T fitting could be installed on tube and probe mounted it the T right in the oil.
  • Alc and Paulgo have said thanks
#6 olds45512 OFFLINE
olds45512
  • 1,338 Thanks
  • 677 posts
Posted March 29, 2016 - 04:33 PM
I'd use something like this.
http://www.amazon.co...f_rd_i=15735921
#7 BigFlash OFFLINE
BigFlash
  • 244 Thanks
  • 132 posts
Posted March 29, 2016 - 05:00 PM
I wouldn't mind doing that to my 140, ideally I would drill in tap a whole in the rear axle/reservoir. But i don't think i could ever bring myself to do it.
#8 propane1 ONLINE
propane1
  • 8,465 Thanks
  • 4,036 posts
Posted March 29, 2016 - 06:10 PM
What should the temperature be for fluid. Normal and to hot ?
Noel
#9 Paulgo OFFLINE
Paulgo
  • 689 Thanks
  • 461 posts
Posted March 29, 2016 - 06:22 PM
Noel
Normal is 140-180°F. Max recommended operating temperature for most hydros is 190-195°F.
  • propane1 said thank you
#10 Cvans OFFLINE
  • 6,459 Thanks
  • 6,053 posts
Posted March 29, 2016 - 06:48 PM
220 degs most non-synthetic oils start to break down or form carbon if I remember correctly.
#11 James Bosma ONLINE
James Bosma
  • 1,156 Thanks
  • 585 posts
Posted March 29, 2016 - 07:02 PM
What if you replaced the drain plug with the temp sender, when doing oil change you can inspect the sending unit  and no damage done to the housing
  • limebuzz, propane1 and Paulgo have said thanks
#12 Paulgo OFFLINE
Paulgo
  • 689 Thanks
  • 461 posts
Posted March 29, 2016 - 07:14 PM
That would definitely be the quickest and easiest approach. :thumbs:
#13 warrior120 OFFLINE
warrior120
  • 56 Thanks
  • 74 posts
Posted March 29, 2016 - 07:39 PM
Interesting idea I think it would be something to look into
  • propane1 and Paulgo have said thanks
#14 olds45512 OFFLINE
olds45512
  • 1,338 Thanks
  • 677 posts
Posted March 29, 2016 - 08:02 PM
the only negative i see to that idea is that it would put the wire and the sending unit down low where it could get damaged.
Edited by olds45512, March 29, 2016 - 08:02 PM.
  • propane1, Paulgo, James Bosma and 1 other said thanks
#15 propane1 ONLINE
propane1
  • 8,465 Thanks
  • 4,036 posts
Posted March 29, 2016 - 08:42 PM
Strap on sensor would be easier I figure. May not give exact fluid temperature, but would let you know if it's heating up. That would also keep the wire more to the top so it won't get tangled up in any thing.
Noel
  • James Bosma said thank you
