Volt meter question.
14 replies to this topic
#1 Paulgo ONLINE
Paulgo
  • 669 Thanks
  • 441 posts
Posted March 29, 2016 - 01:06 PM
Hi All! I have one of those hand held digital volt meters. I mainly use it to keep track of my batteries and tractor charging status. Normal routine is to set it on a battery, while engine running, and then hook up the probes to see how well the engine is charging. I have something odd going on with one GT. When I get my meter close to the battery it starts going crazy. Readings all over the map, and the probes aren't even connected! Obviously some sort of magnetic field coming off the engine. Any ideas ?  Paul
Edited by Paulgo, March 29, 2016 - 01:07 PM.
  • Auburn David said thank you
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 29, 2016 - 01:09 PM
Called Phantom readings and could be anything.
  • ducky and Paulgo have said thanks
#3 ducky OFFLINE
  • 1,961 Thanks
  • 4,085 posts
Posted March 29, 2016 - 01:12 PM
I have seen florescent lites do that.
  • Auburn David and Paulgo have said thanks
#4 Eric OFFLINE
Eric
  • 1,253 Thanks
  • 783 posts
Posted March 29, 2016 - 01:21 PM
This is why I use a trusty fifties Era analog meter, just my preference though.
#5 Paulgo ONLINE
Paulgo
  • 669 Thanks
  • 441 posts
Posted March 29, 2016 - 01:31 PM
First time I've ever had it happen. Weird.
#6 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,378 Thanks
  • 4,084 posts
Posted March 29, 2016 - 01:44 PM
Low battery in the meter? I can see electro-magnet affecting an analog meter as the meter movement is a magnet and coil, but not a digital meter.
Check the settings incase you have selected a high OHM or Low Current setting.
Edited by larrybl, March 29, 2016 - 01:44 PM.
  • WNYTractorTinkerer and Auburn David have said thanks
#7 Paulgo ONLINE
Paulgo
  • 669 Thanks
  • 441 posts
Posted March 29, 2016 - 01:58 PM
Had two tractors running 20 feet apart. Walked back and forth. Worked fine on one and freaked out every time I got near the battery on the other. Checked battery after shutdown and reading was just dandy. Started back up and away she went!
#8 speedbird OFFLINE
speedbird
  • 256 Thanks
  • 135 posts
Posted March 29, 2016 - 05:24 PM
It could be radiation from the ignition system. Check the plug, plug wire or try some shielding. It's a long shot but possible
#9 Paulgo ONLINE
Paulgo
  • 669 Thanks
  • 441 posts
Posted March 29, 2016 - 06:26 PM
I swapped the ratty looking plug wire for a nice one I had on hand. I wonder if it is the wrong type of wire??
#10 JiminRI OFFLINE
JiminRI
  • 82 Thanks
  • 78 posts
Posted March 29, 2016 - 07:09 PM
Can you swap spark plug wires on the two tractors you mentioned? If the problem moves, you know it was the new wire.
Good luck,
Jim
#11 Paulgo ONLINE
Paulgo
  • 669 Thanks
  • 441 posts
Posted March 29, 2016 - 07:15 PM
Good luck,
Jim
That will be my next move. :thumbs:
#12 Eric OFFLINE
Eric
  • 1,253 Thanks
  • 783 posts
Posted March 30, 2016 - 01:48 AM
Radiation? I have never heard of a battery putting off radiatin
#13 Paulgo ONLINE
Paulgo
  • 669 Thanks
  • 441 posts
Posted March 30, 2016 - 07:57 AM
He was referring to the plug wire and coil next to the battery.
#14 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,822 Thanks
  • 2,413 posts
Posted March 30, 2016 - 08:28 AM
These small engines like wire-core plug wires.
Carbon-core (resistor) plug wires are not desirable.
  • Paulgo said thank you
#15 toppop52 OFFLINE
toppop52
  • 4,587 Thanks
  • 4,294 posts
Posted March 30, 2016 - 08:41 AM
Radiation of electricity from a bad wire, cracked insulator or from the coil, points, condenser, generator, magneto or anything in the electrical system can cause scatter that the meter will pick up.
