Transaxle oil GT18
3 replies to this topic
#1 scottgt18 OFFLINE
scottgt18
  • 1 posts
Posted May 03, 2011 - 06:14 PM
I have a 1980's GT 18hp with a 6 speed high/low transaxle. The manual doesn't list the type of oil to use. Any ideas. Thanks.
#2 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 03, 2011 - 06:41 PM
80W-90 gear oil
#3 mkasey OFFLINE
mkasey
  • 3 posts
Posted November 08, 2011 - 12:20 PM
What kind of shape is your GT18 in? I have one too, bought it new, but I think it needs a float for the carb. Onan parts are like gold if you can find them.
#4 dangeroustoys56 OFFLINE
dangeroustoys56
  • 19 Thanks
  • 22 posts
Posted February 29, 2012 - 09:05 AM
Ive herd to use regular motor oil in it - mainly for the fact that the tolerances are so tight , has mostly all gears inside - the other reason would be for cold climates - heavy oil wont be picked up easily by the gears .
I actually put a whole quart of Lucas oil motor oil additive in my 86 GTII ( im down south) - stuff sticks to everything it touches - figured if the stock trans in one of my mod tractors has held up with it in it, should be good enough for a stock tractor.
I also have a 90's GT6000 that came with a non running onan 20HP twin - basically thats a parts machine - too bad because its one with all the bells and whistles .
