Montgomery Wards Tiller Woes!
12 replies to this topic
#1 CaptianRon OFFLINE
CaptianRon
  • 5 Thanks
  • 32 posts
Posted March 28, 2016 - 07:35 PM
Ok I have an old 8 hp rear tine Montgomery Wards Perfectionist tiller that has given me great service up until the tank rusted on me. I removed that tank and grabbed a plastic one off of and old riding mower. Never could get it to run right with that tank on there. Cleaned out the carb multiple times but still no go. It would run 5-10 minutes and then crap out on me. I finally said screw it and bought a new tank just like what came on it new and a new carb.
I've got it to where it will crank and run like a top for about 5-10 minutes again and then it dies. the in line fuel filter looks like it's running out of fuel. It gets about 1/2 full of fuel when it dies.
Anyone got any ideas?
I got the biggest fuel filter I could get thinking it would give me more flow.
Is filter placement an issue? it's right before the carb.
Am I off track and it's something else completely?
I usually don't have issue with these little engines but this one has me ready to give up gardening!!
  • kathrynhn4 said thank you
#2 lyall ONLINE
lyall
  • 2,250 Thanks
  • 1,602 posts
Posted March 28, 2016 - 07:44 PM
it could be the fuel filter.
there are two different types of fuel filters.  gravity and pressure types.
the gravity type flows earier
the pressure type is used with a gas pump
you need to be using a gravity type.
using a pressure type on a gravity type, the gas does not flow as it should.
the material in the gravity type filter is courser then the pressure type.
  • jms180 and CaptianRon have said thanks
#3 CaptianRon OFFLINE
CaptianRon
  • 5 Thanks
  • 32 posts
Posted March 28, 2016 - 07:54 PM
Hmmm not sure how to tell if it's gravity or not.  It's a clear plastic filter with paper medium. They were in the lawn and garden section at my local ACE hardware.
#4 lyall ONLINE
lyall
  • 2,250 Thanks
  • 1,602 posts
Posted March 28, 2016 - 08:01 PM
B&S fuel fitlers
a red one is for motors with-out fuel pumps
a white one is for motors with fuel pumps
check the following site for more info and filter fits each motor
http://www.jackssmal...rt/Fuel-Filters
  • CaptianRon said thank you
#5 CaptianRon OFFLINE
CaptianRon
  • 5 Thanks
  • 32 posts
Posted March 28, 2016 - 08:07 PM
B&S fuel fitlers
Well bust my freakin buttons!!!! Yep mine is for a pump! Well I think anyway. It looks just like the top filter on your link. That filter doesn't say either way though?
#6 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted March 28, 2016 - 08:12 PM
Did you run a new fuel line when you replaced the tank and carb?
#7 lyall ONLINE
lyall
  • 2,250 Thanks
  • 1,602 posts
Posted March 28, 2016 - 08:31 PM
did some checking on micron sizes
the B&S red fuel filter uses 150 microns
the white fuel filter uses 75 microns.
so the larger the micron size the easier  for gas to flow thru.
#8 CaptianRon OFFLINE
CaptianRon
  • 5 Thanks
  • 32 posts
Posted March 28, 2016 - 08:32 PM
yep new everything.
  • Cat385B said thank you
#9 DougT ONLINE
DougT
    Dog Approved
  • 7,152 Thanks
  • 5,103 posts
Posted March 28, 2016 - 08:55 PM
since it's all new, take the filter out and connect the hoses. Shouldn't hurt to run it for a bit. It would tell you if that was the fix or not.
#10 Clifford Bridgford OFFLINE
Clifford Bridgford
  • 423 Thanks
  • 136 posts
Posted March 28, 2016 - 09:19 PM
Is the vent on the gas tank cap open?
Cliff
#11 CaptianRon OFFLINE
CaptianRon
  • 5 Thanks
  • 32 posts
will probably do that tomorrow.
  • DougT said thank you
#12 CaptianRon OFFLINE
CaptianRon
  • 5 Thanks
  • 32 posts
Posted March 28, 2016 - 09:30 PM
Cliff
yepper.
#13 CaptianRon OFFLINE
CaptianRon
  • 5 Thanks
  • 32 posts
Posted March 29, 2016 - 08:52 PM
Turns out it was absolutely the filter. Put that little red bugger on and she started first pull and never died once!!
My first run of the season and look what she done. This long strip is about 100', the patch down closer to the house is about 25' x 25'
IMG_20160329_193405.jpg?t=1459216211
  • 29 Chev said thank you
