214 solenoid question
21 replies to this topic
#16 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted March 27, 2016 - 09:49 PM
the purple wire goes from the switch to the PTO switch to the neutral switch then to the solenoid.
Thanks Glen.
#17 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted March 27, 2016 - 10:43 PM
How I check a solenoid - shake real hard so that the center of the solenoid can move.  If you do not feel a movement in the solenoid, I do not use it.
how a solenoid work see link https://www.youtube....h?v=hsoggQOoG4s
also are you leaving the switch for long periods of time?  if so the fuse might be the problem.  If the fuse get hot it will short out.
note the second post that larrybl has for testing a switch - is is for a magneto switch
a battery switch has the S in the position that M is.
 the 110 series manual - section 40 electrical section will answer most of your question
#18 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted March 28, 2016 - 01:35 PM
Took everyone's advice and traced the problem down with test light. Lyall (Glen) suggested to check circuit breaker too and that was the culprit. Tractor would crank several times and then nothing. Apperntly fuse was getting hot and would trip and then when it cooled down it would reset, letting it crank again. Pesky lil bugger!
Thanks all!
PS: bought a new 20 amp breaker at Napa for $3.99 and tractor runs fine now.
Edited by coinman66, March 28, 2016 - 01:36 PM.
  • lyall and WNYTractorTinkerer have said thanks
#19 JD318420 OFFLINE
JD318420
  • 65 Thanks
  • 97 posts
Posted March 28, 2016 - 01:52 PM
Excellent! The replacement was it all plastic (including the mounting) or metal?
#20 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted March 28, 2016 - 03:03 PM
All metal. Bracket is metal too. Is that good or bad?
#21 JD318420 OFFLINE
JD318420
  • 65 Thanks
  • 97 posts
Posted March 28, 2016 - 03:59 PM
Thats good in my book, plastic ages and then cracks, I like replacements parts of good quality! John Deere I believe the replacements are now plastic. Have to go check my spares, yep plastic! :(
  • coinman66 said thank you
#22 easternharvest OFFLINE
easternharvest
  • 155 Thanks
  • 140 posts
Posted April 02, 2016 - 05:49 PM
Listen to these guys, I was frustrated as heck doing the same thing as you. Turned out the brand new ignition switch I bought was bad...
