A few questions on a Massey 1655
160 replies to this topic
#61 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 13, 2016 - 10:50 PM
Another update....
Finished up the axle mounts for the loader. Now I currently have the rear axle removed. One now my homemade gaskets failed on the pump. Ordered 2 Oem gaskets from Messicks in PA. 6 a piece plus shipping was fine for me. Got those done and now trying to remove a wheel hub. It's being extremely stubborn. The axle seal is leaking so thought this would be a good time to fix it.
Got the torch on it now hoping for a miracle. It's defintely not corroded. Key looks good. Just doesn't want to move. Anyone have any tricks?
Eric
  • olcowhand, limebuzz and KennyP have said thanks
#62 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 13, 2016 - 10:51 PM
Forgot a pic of the loader actually on now. Hopefully, I'll drive it out before snow falls around here.
Eric
  • olcowhand, DMAX, limebuzz and 2 others have said thanks
#63 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 13, 2016 - 10:57 PM
The miracle happened!!!! Let the torch sit about 5 minutes. Shut off and tapped it with the hammer. She fell off. Key is good. Just need to pull the tube now. Hoping I can source this seal from Napa. I know the Deere 400 uses a similar setup. I'm gonna try the Napa number I got from a thread I found on those. Hoping it matches.
Eric
Eric
  • olcowhand, limebuzz, Alc and 1 other said thanks
#64 massey driver OFFLINE
massey driver
  • 1549 Thanks
  • 1613 posts
Posted November 14, 2016 - 08:20 AM
How's this  National seal  481792   [ 1.125 x 2.125 x 0.250 ]
  • DMAX, limebuzz and dropped82 have said thanks
#65 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 14, 2016 - 04:36 PM
I went to Napa and had it crossed over. He came up with the ID and OD. The thickness was .313 though. They had to order it from the warehouse so I'll get it tomorrow. I'm going to guess the thickness will still be fine. Thanks for the number. Saved me some searching.
Eric
Edited by dropped82, November 14, 2016 - 04:37 PM.
  • massey driver said thank you
#66 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 23, 2016 - 08:48 PM
Well the seal from Napa fit perfectly. Rearend is now all together and back in the tractor. I flipped the rear wheels for a wider stance. Got me the clearance I need. After all that, I went on a hunt for an oil leak on the engine. The result....a cracked oil pan where the drain tube screws in. Man this machine is making me earn my loader. Getting things together on the rear and middle. Then to pull the engine again!! Luckily I have a parts engine with a good pan.
Eric
Edited by dropped82, November 23, 2016 - 08:49 PM.
#67 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted November 24, 2016 - 05:36 AM
Eric, this tractor will make you forget the little set backs when it's finished. Great build your doing.
  • dropped82 said thank you
#68 Alc OFFLINE
  • 8983 Thanks
  • 8293 posts
Posted November 24, 2016 - 05:55 AM
The cracked oil pan when your so close stinks . Will you try repairing it ?
#69 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 24, 2016 - 11:07 AM
No...I don't want a chance for a repair to fail. I'd rather just replace it with a good one. I can experiment with the pan afterwards maybe. With the list of things piling up after this is done, it may be a bit before I get to it.
Eric
  • olcowhand, limebuzz and Alc have said thanks
#70 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 29, 2016 - 11:56 PM
No pics tonight. Managed to get the engine out. Swapped the oil pan. Still have to reinstall it. The crack was about 3" long. Worse than what I thought. I'm going to change the drain tube. Right now it comes straight out with a plug. Everytime the plug is tightened, the tube is tightened. Eventually cracking the pan. Going to add a turn down on the drain. Will prevent turning both while reinstalling drain plug. That's about all I have done. I'll post some pics tomorrow. Hopefully of it back in the tractor.
Eric
  • olcowhand, limebuzz, KennyP and 3 others have said thanks
#71 KennyP ONLINE
  • 50117 Thanks
  • 52295 posts
Posted November 30, 2016 - 05:41 AM
Sounds like a correct fix!
#72 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted December 26, 2016 - 10:46 PM
Little update. Been a while but for good reason. I've spent all this time adding fluid to the hydro/transaxle. As many know, it takes a while. Work has called. Wondering where I've been.
On a serious note, I snagged all my fittings and return hose for the loader. Haven't had much time due to the holidays. I am filling the hydro unit tonight. Here's hoping for no leaks.
Eric
  • limebuzz and KennyP have said thanks
#73 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted December 29, 2016 - 08:49 PM
So, I went out today and got the last few fittings I need (thought I already had them, Nope!!) Found all but 3 things. My local tractor supply sucks. Their stuff is a mess and half is out. Grabbed what I thought was a 36" pressure hose and it was only 24! Glad I checked. My local Napa will have what I need hopefully but they closed before I got back in town. Still need 2 90 hydraulic fittings and a fuel tank grommet. I also managed to lose the grommet I had tonight while out shopping. Can someone tell me the size or show me to where I can source these? Mine was cracked and dripped fuel.
Eric
Edited by dropped82, December 29, 2016 - 08:50 PM.
  • limebuzz and Alc have said thanks
#74 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted January 12, 2017 - 02:18 PM
So..................
I'm a set of tires and a choke cable away from being done. Everything after that is purely cosmetic. That'll come eventually. Need it to function first. Just finished swapping the carb for a better one (I think). Mounted and plumbed the pump. Tightened all the hoses and clamps. I'm at the turn key point.
How many of you have worked on something for so long, your almost scared to start it? I'm just as nervous as I'm excited. Send some prayers my way. The luck will surely follow.
Eric
#75 KennyP ONLINE
  • 50117 Thanks
  • 52295 posts
Posted January 12, 2017 - 02:20 PM
I'll be listening for the roar as it comes to life!
  • dropped82 and Jonas Monnett have said thanks
