A few questions on a Massey 1655
160 replies to this topic
#151 jpswift1 OFFLINE
jpswift1
  • 888 Thanks
  • 672 posts
Posted November 07, 2017 - 06:11 PM
I got one more issue I wanna tackle with this machine. The one thing every loader tractor should have, power steering. I got a donor machine. Just need the time. Stay tuned..................
And then finally I might install the pretty dash decal I got from Limebuzz!!
I installed my dash decal that I got from Limebuzz, and it's GREAT!  You'll be very happy!
  • limebuzz said thank you
#152 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted March 14, 2018 - 06:08 PM
Got a new addition to the loader!! Found this tooth bar while perusing Home Depot site. It is a Swisher. Meant for the bucket they make for 4 wheelers. It's 44" wide but of centered fits the loader bucket nicely. I still have to do some work on the edge before I install it but shouldn't be to hard.20180314_190342.jpg
  • olcowhand, DMAX, limebuzz and 3 others have said thanks
#153 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted March 14, 2018 - 06:26 PM
Looks good Eric
  • dropped82 said thank you
#154 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted April 09, 2018 - 08:32 PM
Need some ideas on where to plumb in a hydro cooler. Spent the weekend working it and I noticed things started getting a little louder and slower. Popped out the took tray and felt the rear. She was hot!!! I'm thinking the extra HP has something to do with that. Any thoughts?
#155 Jonas Monnett OFFLINE
Jonas Monnett
  • 259 Thanks
  • 151 posts
Posted April 09, 2018 - 08:35 PM
What About Hook Up A Small 12v Fan To Keep It Cool??
  • Mark 149 J. said thank you
#156 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
It already has a fan. I'm needing to add a separate cooler.
#157 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted April 09, 2018 - 08:36 PM
 Plumb your connections on your hydro return line right at the hydro.  The only place to put the cooler is in front of the engine cooling intake, and it's kinda tight in there.  That is unless you get a cooler with it's own 12V fan.  My Bush Hog JB1 with the twin Wisconsin engine, it's hydro got way hot on one of my plow days.  Started leaking hydro oil past all the gaskets it got so hot.
  • dropped82 and Mark 149 J. have said thanks
#158 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted April 10, 2018 - 02:37 PM
I have an extra Case oil cooler laying on the shelf. Also have one from a Duetz 1920. Seems the Case with an electric fan wouldn't be too hard. Would let me hang it just about anywhere. I'm assuming your talking the hard line that goes from the rear case to the pump body?
#159 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted April 10, 2018 - 03:01 PM
No, it's the line that returns off the hydraulic remotes.  Just plumb the cooler between the hydraulic remote return port and the hydro unit.
  • dropped82 and jpswift1 have said thanks
#160 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted May 22, 2018 - 03:36 PM
Had some goodies arrive in the mail today. Thanks to a fellow member, I get to add a few more options to the 1655 loader.20180522_160910.jpeg
  • olcowhand, limebuzz and mac102004 have said thanks
#161 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted June 12, 2018 - 12:59 PM
Went to the Lawn and Garden tractor Extravaganza in Evansville last Saturday. Things were fairly inflated as usual but happened upon this. Then just so happened to meet a fellow member. He made me a great deal on this setup and we chatted a while. He has another machine I might make a trip to get. We will see....
Once I get some other jobs done, I'm going to pull the Massey back in the shop and start installing all this stuff.20180611_184827.jpeg
Edited by dropped82, June 12, 2018 - 12:59 PM.
  • olcowhand, KennyP and jpswift1 have said thanks
