A few questions on a Massey 1655
160 replies to this topic
#136 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted October 07, 2017 - 08:12 PM
Yes, 12V battery powers the coil. The pickup ring & module serves as a breaker.
Thanks for that!!!
Something I also noticed is the different flywheels. The p224 flywheel center protrudes out farther. That would make my driveshaft pulleys not sit in the correct spot causing belt alignment issues. Going to swap on another flywheel from a B series engine I have. Looks like it should be a painless change over. Although the shroud will not line up correctly after the swap. This might take some modifications. The B series shrouds are too narrow for the big block so I'm stuck using the p224 shroud.20171007_210804.jpg
Edited by dropped82, October 07, 2017 - 11:37 PM.
  • olcowhand and KennyP have said thanks
#137 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted October 07, 2017 - 08:15 PM
I've swapped the flywheels before for the same reason, but my tins were interchangeable, so it worked great.  The flywheels should interchange for you, but you will have that gap.
  • dropped82 said thank you
#138 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted October 07, 2017 - 08:29 PM
This being a loader tractor, things flying around would be less. I'd be more concerned if it had a mower deck under it. I'm gonna run it with the gap until I find the correct one. I'll just have to pay more attention to keeping the head tins cleared out.
#139 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted October 09, 2017 - 09:33 PM
I had a little time today. Managed to install the stator and correct flywheel. Doesn't seem like much but getting closer. At this point, it's pretty much starter and tins left.20171009_222030.jpg 20171009_223131.jpg
  • olcowhand, limebuzz and KennyP have said thanks
#140 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 02, 2017 - 10:28 PM
Made a little progress last night and tonight. Works been busy so I've been too tired to work on things. Plus, trying to squeeze in some fishing trips before winter truly sets in and I have to winterize my boat. Got the engine in. Tried the hood. I thing by bending a few spots around the heads, it'll close without issue. Right now, it doesn't but will be amended.
After setting the engine, I had to sort the throttle control. This engine was on a sawmill so clearly the hand control on the engine will not work. After drilling one hole, I was able to add an Onan throttle and governor spring. Next comes wiring!!20171102_224631.jpg
#141 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 03, 2017 - 05:04 PM
Carb on and igntion/charging system hooked up. Getting closer.
There's a local plowday next weekend. I would really like to take this with me.20171103_174911.jpg 20171103_174922.jpg
#142 KennyP ONLINE
  • 51846 Thanks
  • 52913 posts
Posted November 03, 2017 - 05:42 PM
There's a local plowday next weekend. I would really like to take this with me.attachicon.gif20171103_174911.jpgattachicon.gif20171103_174922.jpg
Better get after it then!
#143 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 04, 2017 - 12:18 AM
Needs an oil filter and fuel. Wait till tomorrow though. I'm pooped.20171104_005827.jpg
#144 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 04, 2017 - 01:47 PM
It's alive!!!! and wow does she have some power now. This should've been a factory option. Here's a couple pics and a video.
https://youtu.be/XMlaD1UMlHs20171104_142204.jpg 20171104_142158.jpg
  • limebuzz and KennyP have said thanks
#145 KennyP ONLINE
  • 51846 Thanks
  • 52913 posts
Posted November 04, 2017 - 01:55 PM
Glad you have it running!
#146 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted November 04, 2017 - 05:19 PM
Sounds good Eric!   :thumbs:
#147 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 06, 2017 - 10:02 PM
Now need to tackle wrapping the hood around. And I'm not being sarcastic. The p224 is 3" overall wider. The B43 was close to the hood. It hits this one. Also, air cleaners are completely different. The shroud inside the hood had to be trimmed. Then I took an adjustable wrench and slowly massaged the lip around the bottom out until it cleared the head.
And here ya go. It's on. Main issue that I missed is the height of the muffler. The tip barely made it out and really high. The hood is touching the muffler. I plan to paint this so that will be an issue. An issue I'll address after this weekend's plowday. I can cut and shorten each header and get a better placement. The more I look at it, after dropping the muffler down away from the hood. I might add to the tip and turn it down to the ground, past the pump. Instead of out the front.
Edited by dropped82, November 06, 2017 - 10:15 PM.
#148 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 06, 2017 - 10:04 PM
I got one more issue I wanna tackle with this machine. The one thing every loader tractor should have, power steering. I got a donor machine. Just need the time. Stay tuned..................
And then finally I might install the pretty dash decal I got from Limebuzz!!
Edited by dropped82, November 06, 2017 - 10:07 PM.
  • limebuzz, KennyP and jpswift1 have said thanks
#149 KennyP ONLINE
  • 51846 Thanks
  • 52913 posts
Posted November 07, 2017 - 05:59 AM
Take plenty of gas to the plow day as I hear those big Onans love the stuff!
#150 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted November 07, 2017 - 07:44 AM
If economy was my intent, it would be a Honda. Power is the goal here. I plan to have an extra can just for this machine haha.
Edited by dropped82, November 07, 2017 - 07:45 AM.
