Pull behind sprayer - B&S 3HP pulsa-jet part numbers
pulsa-jet briggs 3hp
5 replies to this topic
#1 rugbywarrior89 OFFLINE
rugbywarrior89
  • 33 Thanks
  • 39 posts
Posted March 26, 2016 - 11:14 AM
I just found a 30 gal sprayer on craigslist and picked it up.  it came with a B&S 3HP engine 80202-0659-01.  The briggs website and gttalk manuals section do not have the parts list for this thing.  It comes with a pulsa-jet carb.  The engine runs with gas put into the carb but it doesn't pull gas from the tank.  I'm sure its the diaphram and I want to purchase a carb rebuild kit.
1. Does anybody have a parts list/ manual for this engine?
2. Does anybody know the correct carb kit?  I'm think this (link to amazon) is the correct kit based on the carb/gas tank gasket having two holes but I'm not sure.  Can anybody shed some light on this?
  • mirandaua2, paulinepi4, irisbh4 and 1 other said thanks
#2 boyscout862 OFFLINE
  • 13,440 Thanks
  • 9,385 posts
Posted March 26, 2016 - 02:00 PM
If that is the type with the carb mounted on the tank, The pickup tubes are usually plugged. I don't know the numbers. Good Luck, Rick
  • rugbywarrior89 said thank you
#3 drbish OFFLINE
drbish
    Collecter
  • 1,571 Thanks
  • 1,370 posts
Posted March 26, 2016 - 03:35 PM
Illustrated Parts List 80200 to 80297
81200 to 81297
Attached File  80200.pdf   3.42MB   68 downloads
#4 MNGB OFFLINE
MNGB
  • 2,493 Thanks
  • 1,522 posts
Posted March 27, 2016 - 02:31 PM
As posted check the pickup tubes they could be plugged or some have a sleeve coupler that can go bad, although its not a bad idea to get a carb kit.
#5 rugbywarrior89 OFFLINE
rugbywarrior89
  • 33 Thanks
  • 39 posts
Posted April 02, 2016 - 12:01 PM
Pickup tubes were fine although I broke the shorter one trying to take it off the carb.  It broke off flush with the surface so I'm not sure how to get at it or replace it.  I was thinking of trying to drill the plastic tube out then replacing it with a tine hose.  otherwise, I'm not sure what to do.
#6 drbish OFFLINE
drbish
    Collecter
  • 1,571 Thanks
  • 1,370 posts
Posted April 03, 2016 - 04:30 PM
Here is the pickup tube you need.From what I can tell it is part number 497413s which replace 296811
http://www.ereplacem...483_243097.html
Also tagged with one or more of these keywords: pulsa-jet, briggs, 3hp
