Got a call from a nice guy whose Dad had passed away. Pictures were sent and a deal was made. I will keep the D4-12 and the bumper off the D4-10. Rest most likely will be sold.
That is a nice haul. The plow and the hiller are both made by Brinly and attach to a sleeve hitch. The hiller is actually a cultivator frame, with what looks like home built moldboards. I am planning on trying to make some similar moldboards later today, and I may run them on my cultivator frame as well.
The first picture shows the cultivator attached to the sleeve hitch, the second picture is a close up of the sleeve hitch.
Man! Couple years ago never Knew Bush-Hog even made tractors, and now YOU own most of them! Heh! Seems they are more popular out East there. Why is that, when they were made in Colorado or such weren't they?? Not sure I've ever seen one personally in Mid-West shows I've been to, Even Portland, IN one?? Never cared for the early little ones, but like the big ones with the tool box fenders and such.
I knew the steering was out on the 12. Figured it was the caste steel part had broken- I expected to replace it, but wow. That part is a goner for sure!
Scott, that's cast iron. If it were cast steel it would be a snap to weld. I welded one up with nickel rod, then cooled it slow, and after a couple years, it broke again.
And that arm is almost surely home brew to serve as a anti-sway bar.
I believe DH1 and Oldcowhand are correct that that part is home built. Possibly as an anti-sway bar, but factory built sleeve hitches have two bolts that you tighten to eliminate sway. It may also have been part of a lift mechanism to adapt it to something other than a sleeve hitch.
Cast iron is a snap to weld, just clean it really well then use mg250 stick rods. after the weld take the sharp end of a chipping hammer and peen the weld while it cools. after it cools of a bit but before it gets cold put the next pass in. when you are all done wrap it in insulation and leave it for the night. then grind clean and go. I woudnt mind having one for those front bumpers or even the dimensions so I could make one.
ditto on the brazing for cast iron parts. problem with that part is that it looks like it has been welded before, its somewhat large, and it sees a lot of stress and ultimately will likely fail again. I assume its the same as used on the d410 and you could just swap it out from a parts unit. quicker, easy and more reliable.
Very nice score Scott. How many more models do you need to find yet in order to make the collection complete? Can't be many more models to find yet? I'm rooting for you, and hope you'll find everything by the end of this year!
You keep finding these tractors, and your collection will out number mine in no time! :smilewink:
Related Threads
Garden Tractor Forums
951.2K posts
49.2K members
Since 2010
