Homemade Implement-keep it or sell it
22 replies to this topic
#1 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted March 25, 2016 - 07:11 PM
ImageUploadedByTapatalk1458950918.582106.jpg ImageUploadedByTapatalk1458950938.847830.jpg
I got this in a load I brought home this week. Trying to decide what to do with it. Guess I could always take the cut off railroad track piece and use it for weight on a tractor. Any thoughts?
Edited by sacsr, March 25, 2016 - 07:36 PM.
  • DH1, wvbuzzmaster, Oldford and 2 others have said thanks
#2 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted March 25, 2016 - 07:13 PM
Looks like a disk for a walk-behind being so narrow!
  • sacsr and chieffan have said thanks
#3 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted March 25, 2016 - 07:35 PM
It's heavy for sure! Not sure how it was attached to what ever it was used on.
  • chieffan said thank you
#4 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted March 25, 2016 - 07:37 PM
Parts for a new project.
I'd break it down and turn it into an offset disc, the current configuration would be leaving a ditch behind every pass. The steel may be rusty but it looks solid. I make a point of never turning down extra steel.
Of course, free steel is always best
And I'd turn the rail into an anvil. My gramps had one like that.
Edited by Chopperhed, March 25, 2016 - 07:38 PM.
  • MH81, sacsr, oldedeeres and 3 others have said thanks
#5 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted March 25, 2016 - 07:40 PM
That slot in the channel iron on the front may hold a clue on the attachment point!
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted March 25, 2016 - 07:43 PM
Three blades like that  are used as a Hipper to make raised rows and to hill potatoes.
However the cups should be reversed to push soil to the center.
If I had that I would scrap it and build just that.
#7 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted March 25, 2016 - 07:48 PM
An after thought, in NC could those have been used to hip rows for tobacco?
Not much grown up here. Though I am told my wifes great grandfather grew enough to keep his pipe gowing. I have also seen pictures of a plow device with Mule Ear shapped shovels.
Edited by JD DANNELS, March 25, 2016 - 07:51 PM.
#8 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted March 25, 2016 - 07:49 PM
Years ago there was tobacco grown all around me.
#9 Alc ONLINE
  • 7,246 Thanks
  • 7,589 posts
Posted March 26, 2016 - 05:16 AM
The rail piece makes a good makeshift anvil , it looks a little smaller then the one I use but still good
  • MH81, sacsr and chieffan have said thanks
#10 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted March 26, 2016 - 08:21 AM
If I got something like that, the first thing I would do is take it for a test run to see how well it works, then decide on what to do with it from there. I like your idea on using the piece of rail as a tractor weight. I have a piece around here somewhere that I use as an anvil, but I think it will be a dual purpose piece from now on.
Jim
  • sacsr, TomLGT195, Sawdust and 1 other said thanks
#11 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 26, 2016 - 12:37 PM
I have a 20ft section of rail..never been able to cut it.
  • Sawdust and chieffan have said thanks
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted March 26, 2016 - 01:34 PM
I have never done it but have heard of my wifes grandfather who had been a foreman on the Chicago Northwestern line doing it.
He would take a chisel and score a break line all the way around the rail then hit it with a hammer.(much the way you would cut a brick or block.
  • Alc, sacsr, Auburn David and 1 other said thanks
#13 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted March 26, 2016 - 01:40 PM
The rail makes a good anvil, but they ring like crazy, I plan to put mine in a sand box to muffle it some.
Use it as it comes, not like I made mine as that is too much work.
I cut a horn on mine and cut a hole for chisels. Wasted a lot of good drills and grinding wheels doing that.
It took weeks to shape the horn with a 4 1/2 inch grinder.
The rails carrying tons over the years gets work hardened to the point the first 1/4 inch is nearly impossible to work. they wear heavily on the inside and takes a lot of grinding to get a reasonably flat crown.
Edited by JD DANNELS, March 26, 2016 - 01:42 PM.
  • KennyP, sacsr, Sawdust and 3 others have said thanks
#14 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted March 26, 2016 - 01:53 PM
Mine is just a cut section about 2' long. I found it that way, I have no idea who cut it or how. I have seen one that had a tapered end on it. It was owned by a farrier and I assume he made it himself, but I didn't ask him about it.
Jim
  • sacsr and Auburn David have said thanks
#15 oldedeeres OFFLINE
oldedeeres
  • 10,492 Thanks
  • 5,096 posts
Posted March 26, 2016 - 01:58 PM
My Olde Deere used a twenty foot length of railway iron for an anvil too. It is mounted up on legs and he put a press over one end and could lay a sickle bar on it to change out the sections on a swather knife. It has a multitude of uses, so much so that when we moved here we hauled it 300 miles! Old iron was never thrown out, but repurposed endlessly. Even now I can't pass up a "dead" bit of machinery without wondering what I could use it for.
  • KennyP, sacsr, Bmerf and 1 other said thanks
