Cat 0 implement option
kolpin
6 replies to this topic
#1 MiCarl ONLINE
MiCarl
  • 2,204 Thanks
  • 1,122 posts
Posted March 24, 2016 - 06:13 PM
I stumbled on THIS 3 point hitch system for ATVs/UTVs.
They describe the hitches as Cat 0 (specifically state the 20" draw bar width) so the tool bar must be Cat 0.  Unfortunately the video is old and apparently they've discontinued many of the implements.  They do still sell the disc, chisel plow, cultivator and 48" back blade.  Summit Racing seems to have the best prices and free shipping.  I've linked the pieces below:
Kolpin tool bar
Box 1 and Box 2 are the two halves of the disc.
Chisel Plow
Cultivator
Back blade
#2 KennyP ONLINE
  • 40,859 Thanks
  • 47,088 posts
Posted March 24, 2016 - 06:26 PM
Right proud of those!
  • TheFarm2004 said thank you
#3 MNGB OFFLINE
MNGB
  • 2,615 Thanks
  • 1,566 posts
Posted March 24, 2016 - 09:37 PM
Interesting it always amazes me (I've seen other video of other makes) how they hitch up a piece of machinery behind a 4 wheeler and drive like their nuts must be going 20 mph you in there right mind works dirt at those speeds.
#4 toppop52 OFFLINE
toppop52
  • 5,532 Thanks
  • 4,898 posts
Posted March 24, 2016 - 09:43 PM
If you have a 2" hitch adapter, they sell a slide in sleeve hitch adapter so that any sleeve hitch implements will also work.
#5 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted March 25, 2016 - 12:30 AM
If you ever dropped the subsoiler in the ground i believe your 4 wheeler would come to sudden stop.
#6 MiCarl ONLINE
MiCarl
  • 2,204 Thanks
  • 1,122 posts
Posted March 25, 2016 - 06:16 AM
That's how it's done when the rain is a comin'.
  • Greasy6020 said thank you
#7 markus OFFLINE
markus
  • 14 Thanks
  • 18 posts
Posted April 07, 2016 - 12:43 PM
Most of these 4 wheeler contraptions are surface scratchers and won't go too deep because an ATV isn't really geared for this type of duty and can reek havoc on a typical 4 wheeler tranny . Surface scratchers are ok for scratching a food plot for wildlife but plowing a plot for deep root planting is best left for a tractor . If all you have is an ATV I would invest in a self powered pull behind rototiller , several engine manufactures are now making these , but for ATV use I would also suggest the DR tiller since it raises and lowers from your seat and saves you lots of re-adjusting the height settings . These are heavy tools and will require an ATV sized to use it .
  • MNGB said thank you
Also tagged with one or more of these keywords: kolpin
