Just wondering, case 195
10 replies to this topic
#1 propane1 ONLINE
propane1
  • 8,721 Thanks
  • 4,126 posts
Posted March 24, 2016 - 02:49 PM
The good , bad and the ugly. What are they like ? Your opinions please.
Noel
  • WrenchinOnIt said thank you
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted March 24, 2016 - 03:26 PM
Never had one but I want one
  • propane1 said thank you
#3 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted March 24, 2016 - 04:11 PM
   I dont know about the 195 but I do like my 155, I think the 195's were made before mine.  they would be hydraulic drive and most likely a 10hp kohler which is a bonus.  If I had the choice I would rather have that 195 than my 155 but that is only a personal choice.  that particular one looks to be in nice cond with the hood ornament. tinwork looks straight, overall I like it.  That's my tow cents for whatever its worth.
        Pete
  • WrenchinOnIt and propane1 have said thanks
#4 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted March 24, 2016 - 04:20 PM
Good: Motor, Frame, implements etc. Bad: The axles. They strip I believe....
#5 HANKG OFFLINE
HANKG
  • 6,306 Thanks
  • 3,420 posts
Posted March 24, 2016 - 05:38 PM
I've also a 155 it has become my main work rig I never owned a 195 but I like them also.  Mine is full hydraulic like Pete's and is nice to operate.
#6 oldcasecoltguy OFFLINE
oldcasecoltguy
  • 9 Thanks
  • 9 posts
Posted March 24, 2016 - 06:48 PM
If you are talking about the one in the picture, it looks like a 1966 Case 190 to me, not a Case 195.
#7 propane1 ONLINE
propane1
  • 8,721 Thanks
  • 4,126 posts
Posted March 24, 2016 - 06:53 PM
As far as I know, it's a 67 or 68 195, but I have never seen it in person. What is the difference between a 190 or a 195.
Noel
Edited by propane1, March 24, 2016 - 06:57 PM.
#8 WrenchinOnIt ONLINE
WrenchinOnIt
  • 3,584 Thanks
  • 968 posts
Posted March 24, 2016 - 08:48 PM
Ditto !
#9 Rock farmer OFFLINE
Rock farmer
  • 1,198 Thanks
  • 1,233 posts
Posted March 25, 2016 - 02:42 AM
Hydraulic drive and big rear wheels are the positives.
Short frame and free wheeling down hill are negatives.
Hand speed control and difficulty finding attachments are also concerns.
Joe
#10 oldcasecoltguy OFFLINE
oldcasecoltguy
  • 9 Thanks
  • 9 posts
Posted March 28, 2016 - 10:09 AM
Case 190 Differences Vs Case 195 Differences
Both Case nameplates are located on the dash below the steering wheel
About 2/3rds less Case 1966 190's made Vs 1967/1968's Case 195's made
Case 190 has ag tires Vs Case 195 turf tires
Case 190 has 4.00/4.80 x 8 ft tires/wheels Vs Case 195 16 x 6.50 x 8 ft tires/wheels
Case 190 has screen/mesh grille Vs Case 195 steel bar type grille
Case 190 has For/Rev lever clamped on steering column Vs Case 195 For/Rev lever built in dash
Case 190 has For/Rev ball knob Vs Case 195 For/Rev tapered knob
Case 190 has Ross steering gear Vs Case 195 steering quadrant/steering gear shaft
Case 190 has no steering wheel grips Vs Case 195 steering wheel has grips
Case 190 has hydraulic brake Vs Case 195 has disc brakes
Case 190 has throttle/choke controls bent out at 45 degrees Vs Case 195's come out straight
Case 190 uses a starter solinoid Vs Case 195 uses a starter pushbutton
Case 190 uses a 3-position ignition switch Vs a Case 195 uses a 2-position ignition switch
#11 propane1 ONLINE
propane1
  • 8,721 Thanks
  • 4,126 posts
Posted March 28, 2016 - 11:02 AM
Wow, lots of differences.
Noel
