* * * * * 1 votes
446
5 replies to this topic
#1 Case446646 OFFLINE
Case446646
  • 1 Thanks
  • 2 posts
Posted March 23, 2016 - 10:26 PM
Need some help my 446 starts right up and runs fine for 30 min. Then it starts missing and back firing through carb. I've clean and replaced float and needle valve on the carb. I've cleaned and adjusted the points. Got a coil coming in the mail. Hope that's it the coil tested aliile weak.thanks for any help
  • 14,815 Thanks
  • 15,502 posts
Posted March 23, 2016 - 10:46 PM
Welcome to GTtalk, glad to have you here. It sounds like a bad coil or condenser to me, good luck.
I'm going to move this to the Case forum.
#3 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted March 24, 2016 - 04:13 AM
    Sure does sound like a coil, you say you replaced the float ? is it adjusted correctly ?  those are pretty simple carb and point systems, wait to see what the coil does then maybe play with the float.  if the float is out of adjustment it could be running itself out of gas after a few minutes or under HI rev.
        Pete
  • boyscout862 and My3kidsfather have said thanks
#4 MiCarl ONLINE
MiCarl
  • 2,050 Thanks
  • 1,057 posts
Posted March 24, 2016 - 06:17 AM
Very first thing that occurs to me is clogged vent on the fuel tank.  When it happens try opening the fuel cap and see if it straightens out.
#5 boyscout862 OFFLINE
  • 12,867 Thanks
  • 9,179 posts
Posted March 24, 2016 - 06:20 AM
Welcome to GTT. It could be a constriction in the fuel flow to the carb. I've seen it before that the fuel filter or fuel lines are mostly plugged. The new gas eats the inside of the fuel lines. Occassionaly the vent hole in the gas tank gets plugged. Run it until it has trouble and unscrew the gas cap. If it starts running better in about 10 seconds, then the cap is the problem. Otherwise, let it cool and disconnect the fuel line at the carb. Let the fuel flow into a clean can for a minute. If the flow stays good, the the lines and filter are okay. Last thing, look at the fuel in the can, is there any contamination? If there is flush the system. Good Luck, Rick
  • My3kidsfather said thank you
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted March 24, 2016 - 02:35 PM
:welcometogttalk: :camera:
