What do you cut grass with?
59 replies to this topic
#31 KennyP ONLINE
  • 32,203 Thanks
  • 42,019 posts
Posted March 23, 2016 - 07:14 PM
I only have the Craftsman 4000 ready at this point! It's normally used inside the fence! The 322D takes care of the bigger areas!
  • pharmer said thank you
#32 crossarm OFFLINE
crossarm
  • 58 Thanks
  • 41 posts
Posted March 23, 2016 - 07:29 PM
scag tiger cat
#33 propane1 OFFLINE
propane1
  • 7,117 Thanks
  • 3,572 posts
Posted March 23, 2016 - 07:31 PM
I like the idea of the springs on the simplicity zero turn.
Noel
  • pharmer and toppop52 have said thanks
#34 toppop52 ONLINE
toppop52
  • 4,220 Thanks
  • 3,963 posts
Posted March 23, 2016 - 07:35 PM
Noel
Me too, but mine is an old design that beats the crap out of you when you go fast.
  • pharmer, WNYTractorTinkerer and propane1 have said thanks
#35 glgrumpy ONLINE
  • 7,409 Thanks
  • 7,053 posts
Posted March 23, 2016 - 08:42 PM
I was told that spring suspensions on zero-turns doesn't really do much for ride, too stiff. AND, how could you keep cut even and not scalping if the machine moved up/down all the time, like would do on my rough yard?  Most didn't have shocks, but see more now having those with springs over. I was looking at Simplicity's last summer too, think they are pretty good unit for the money.  SO many models any more, hard to pick one to be happy with.
#36 LilysDad ONLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 10,989 Thanks
  • 8,394 posts
Posted March 23, 2016 - 08:44 PM
'70 WH Electro12, original engine
  • pharmer and MolonLabe have said thanks
#37 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted March 23, 2016 - 08:59 PM
Last few years, I've been using my Noma Canadiana Articulated. ( Stiga Park 2000e)I hung a 42"deck off the front of it, and it can make short work of anything reasonably flat.
When it dies, or I sell it, I'll go back to my little ford LT75.
  • pharmer, propane1 and MolonLabe have said thanks
#38 grnspot110 OFFLINE
grnspot110
  • 3,527 Thanks
  • 2,468 posts
Posted March 23, 2016 - 09:21 PM
Personally, I'm not a big fan of zeros, had a Bush Hog 2554 for nine years, good mower, just not my thing!
I much prefer the older front deck mowers, first a JD F 525, then about this time last year, I found an F725:  HPIM1761.JPG
Takes me about an hour per mowing, same as the Bush Hog!
#39 IHCubGuy OFFLINE
IHCubGuy
  • 1,448 Thanks
  • 1,526 posts
Posted March 23, 2016 - 09:30 PM
The spring suspension is a Ferris design that got adopted to Simplicity's after Briggs Power Products bought both of them.  We use an IS1500 Ferris at work and I gotta say it DOES make a difference for sure.  The cut is really not affected by it from what I have seen and you can run a LOT faster than one without.  Hustler has a setup for their machines called "flex forks" that have a torsion spring setup in the front wheel forks.  My buddy has these on his X one that he mows commercially with and he is pleased with them too.
For my own personal mower I bought a new 36" Hustler Raptor last year.  So far I love it.  Even if it is only their entry level machine it cut my mowing time in half from what it had been with my Cub Cadets.
  • pharmer, WrenchinOnIt and oldedeeres have said thanks
#40 Kmac1 OFFLINE
Kmac1
  • 521 Thanks
  • 221 posts
Posted March 23, 2016 - 09:40 PM
For most of the 3.5 acres I mow it with a Kubota BX2360. I use a 28" Snapper RER I repowered with a 14.5 hp Briggs to mow my ditch. Occasionally I will mow the front yard with my Snapper 48" yard cruiser.
#41 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 5,918 Thanks
  • 3,800 posts
Posted March 23, 2016 - 09:41 PM
1990 Craftsman with 44" deck. I think he is getting worn out with the 3 acre mowing's.
#42 adamjd200 OFFLINE
adamjd200
  • 1,726 Thanks
  • 1,866 posts
Posted March 23, 2016 - 09:52 PM
99.9% of the zero turns around here seem to be Ferris, simplicity, or snapper pro, but that's probably because they're built near by in Munnsville, NY, even a few of the old Ferris mowers with the full sheet metal body.
#43 Phluphy OFFLINE
Phluphy
  • 308 Thanks
  • 401 posts
Posted March 23, 2016 - 10:00 PM
We use Craftsman's, 20 and 18 hp, with 44" decks. Her's is slower hates when I lap her around the 2 acres of our yard.
Her's is the purdy one:Site pic1.jpg 2nd restore project.jpg
#44 Lmiller3358 OFFLINE
Lmiller3358
  • 1,440 Thanks
  • 1,391 posts
Posted March 24, 2016 - 03:54 AM
My Panzer T 70 B, and it's still making money doing it !
#45 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,011 Thanks
  • 855 posts
Posted March 24, 2016 - 06:17 AM
Well I can tell you after parking my posterior on it for two mowing seasons and at two and a half hours a crack it is a HUGE difference over what I previously mowed with (see pics ) as a matter of fact as much as I like a Bolens these two are probably going on the auction block so I can buy another simplicity to use at my mom's .
Simplicity touts their quality of cut and it's no BS , they DO NOT SCALP unless you drop a wheel in a ditch or similar. I bought this unit to take over mowing duties from my Legacy XL when I put the FEL on it ( it's hiding in the back ground in pic) and it was superior in cut and comfort of ride compared to the Duratrac and 1669 . Again I'm a Bolens guy but Simplicity has it going on with there units either Z turns or GT's
The speed at what you can mow at and still achieve quality of cut is amazing, throw maneuverability in and I no longer will mow with anything else.
  • KennyP, IHCubGuy and MolonLabe have said thanks
