Power King Tractor Questions
10 replies to this topic
#1 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted May 02, 2011 - 06:48 PM
No Model # but look like this one.
Can someone tell me the model and year?
Has a Briggs with the same cutout in the hood.
Would Briggs be original?
#2 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted May 02, 2011 - 08:24 PM
I thought the Power Kings in the 70's were all Kohlers but I could be wrong, that one looks to be 1975 to 79 judging from the dash. 2416 or 2418 for a model #. Model # based or rear wheel size and engine hp.
#3 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted May 02, 2011 - 08:34 PM
Hey I was thinking Kohler as well.
What are your thought on the cut out in the hood by the air cleaner?
#4 Alc ONLINE
  • 6,885 Thanks
  • 7,461 posts
Posted May 02, 2011 - 08:52 PM
You had me wondering and went to the garage to check mine . It also has the cut-out in the hood , 2418
  • ducky said thank you
#5 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,329 Thanks
  • 4,954 posts
Posted May 02, 2011 - 09:02 PM
The cutout in the hood is factory. It was for the air filter on the K series Kohler engine that came in all PKs of that vintage.
Edited by Gtractor, May 02, 2011 - 09:09 PM.
#6 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted May 03, 2011 - 07:53 AM
This is from 1977 .[ATTACH=CONFIG]14156[/ATTACH]
Thanks for the scan Alc.
That helps a ton.
#7 Alc ONLINE
  • 6,885 Thanks
  • 7,461 posts
Posted May 03, 2011 - 08:01 AM
That helps a ton.
Your welcome, if you look at the scan close it seems the hood cut-out is a little bigger on the 2418 . Al
#8 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted May 03, 2011 - 08:11 AM
Yea, That really printed Nice. Good detail.
#9 mjodrey OFFLINE
  • 2,356 Thanks
Posted May 03, 2011 - 09:12 AM
Nice Alc.
#10 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted May 03, 2011 - 09:16 AM
The 16 hp Briggs was an option for the later model steel bodied tractors and used the same larger cut out hood and different grill that the 18 hp Kohler used.
#11 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted May 03, 2011 - 09:42 AM
Thanks Usernane
