Front Spring Size?
11 replies to this topic
#1 subdude OFFLINE
subdude
  • 6 Thanks
  • 7 posts
Posted March 21, 2016 - 03:59 PM
Hello All!  Anyone have the size of the springs used on the front of the D4-10 when mounting the front blade? (The ones that go from the front mounts to the blade mount for lift assist)
Thanks
Matt
  • 14,863 Thanks
  • 15,511 posts
Posted March 21, 2016 - 07:18 PM
Matt, I can't help you because I don't have a front blade, but somebody will help you out shortly. Good luck and post some photos of your rig.. :thumbs:
#3 LPBolens OFFLINE
LPBolens
  • 1,419 Thanks
  • 972 posts
Posted March 22, 2016 - 02:43 PM
I have both a 40" (FB-40) and a 48" (FB-48) blade, but only one of the springs you are asking about. I also have no guarantee that the spring I have is original, although it did come with a blade frame. That said, here goes.
The pic shows the spring I do have. The coiled section is appox. 7-1/2" long and 7/8" in diameter.
Edited by LPBolens, March 22, 2016 - 02:43 PM.
  • subdude said thank you
#4 subdude OFFLINE
subdude
  • 6 Thanks
  • 7 posts
Posted March 25, 2016 - 08:10 PM
Thanks LPBolens!  Will get pictures uploaded soon of the tractor.  Still trying to get some parts together so it's not embarrassed to have it's picture taken.
#5 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted March 26, 2016 - 11:53 AM
Not sure my spring is "correct" but the dimensions are .995" wide - see picture for length- I counted 49-50 coilsf3cefe3fb42f1bbd698fddaeced4c4fa.jpg251738c2d883d418e9dd9bc24deffb1f.jpg
  • Texas Deere and Horse, rbooker and subdude have said thanks
#6 rbooker OFFLINE
rbooker
  • 271 Thanks
  • 134 posts
Posted March 26, 2016 - 06:50 PM
so while at lowes this afternoon I checked to see if they may have something that would work and found what appears to be almost exact for $4 each.  1" od x 8 1/2 L x .120.  thanks to you guys for posting what you have.  also got the angle iron to make the pieces these attach to.
  • Texas Deere and Horse, sacsr and subdude have said thanks
#7 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted March 27, 2016 - 03:34 AM
  • LPBolens and subdude have said thanks
#8 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted March 27, 2016 - 07:51 PM
Hey Guys, when trying to match up springs, you also need to have the wire DIA to determine the spring rate. Just a FYI.
  • sacsr, rbooker and subdude have said thanks
#9 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,843 Thanks
  • 2,336 posts
Posted March 29, 2016 - 03:49 PM
Nahhhh, just let it snap when you try to lift it. When that happens, you know you bought the wrong one ;)
#10 rbooker OFFLINE
rbooker
  • 271 Thanks
  • 134 posts
Posted March 29, 2016 - 09:53 PM
so here you have it... the great spring experiment.  I made up the front guides/spring hangers off of scott's pics/measurements but was 1" short on material so could not finish the second one (job for next night at the farm).  figured I would put the single spring on there and give it a whirl. looks like it should work.  most likely the wire diameter is around 0.125 on the original but since I don't have any of those i wanted to find something that would suffice and be as close as possible (and for $4 each if it went ping-pow so be it).  better than ordering almost the exact same spring from grainger for $10 each then paying shipping.
now I need the size/measurements for the lift bars (s2293) that go from the side of the blade frame to front of lift.  if nobody has one I can always try to whip something up.
  • sacsr and subdude have said thanks
#11 subdude OFFLINE
subdude
  • 6 Thanks
  • 7 posts
Posted March 30, 2016 - 05:01 PM
This help?  This is a S2293 lift bar.
Think I finally figured out how to post a pic. Whew!
  • Texas Deere and Horse, KennyP, sacsr and 1 other said thanks
#12 rbooker OFFLINE
rbooker
  • 271 Thanks
  • 134 posts
Posted March 30, 2016 - 06:33 PM
absolutely.  that's exactly what I needed.  thanks!
