Ag tires on front of my 332 John Deere Tractor
6 replies to this topic
#1 bk332 OFFLINE
bk332
  • 2 posts
Posted March 20, 2016 - 05:00 PM
I want to put ag tires on the front of my JD332. Can I put 16X8.5-8 on . Has any one gone with 18X9.5-8 and do the  fid? Bruce
#2 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 20, 2016 - 07:47 PM
Bruce,
If memory serves me correctly, the original front tire size for your 332 is 16x6.50-8. You could probably mount the 16x8.50-8's on the factory rims, however you'll be pulling the sidewalls in quite a bit. The only thing that I'd be concerned about going with bigger or wider tires is, 1: Will it effect your turning radius, and 2: Will it interfere with your power steering cylinder? I think the larger 18x9.50-8 will give you the biggest issues, and I don't think you'll get them mounted on the stock rims.
Edited by johndeereelfman, March 20, 2016 - 07:48 PM.
  • bk332 said thank you
#3 jabelman OFFLINE
jabelman
  • 2,230 Thanks
  • 1,595 posts
Posted March 20, 2016 - 07:58 PM
just wondering what is the advantage of an ag tire on the front. I can see if it's a 4wd. aside from looking cool any benefits?
  • propane1 said thank you
#4 KennyP ONLINE
  • 38,310 Thanks
  • 45,901 posts
Posted March 21, 2016 - 06:50 AM
I won't do Ag's on the front. Either turf or rib tires up there. Just doesn't look right to me.
#5 Nxt2doc OFFLINE
Nxt2doc
  • 628 Thanks
  • 334 posts
Posted March 21, 2016 - 07:55 AM
Pretty much my thoughts. Is there any advantage to Ags' on the front that I'm not aware of. Anybody feel free to chime in.
#6 propane1 ONLINE
propane1
  • 8,722 Thanks
  • 4,129 posts
Posted March 21, 2016 - 09:50 AM
I like three rib up front, for the look, but they have great traction. One solid rib always making contact with the ground. Just my opinion. Depends what you like.
Noel
#7 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 21, 2016 - 07:37 PM
Some guys are installing the ag's up front, mostly during Winter use, as they bite better which aids in turning abilities when using a front blade or plow.
