1253 help
8 replies to this topic
#1 erbucky OFFLINE
erbucky
  • 3 posts
Posted May 02, 2011 - 03:40 PM
I started working on the 1253 I picked up a few weeks ago. After wiring everything back up when I turn the key the solenoid clicks but the starter does not turn. The solenoid looked pretty beat up so I replaced it with a generic one from the farm supply store, same thing happened. Now I am thinking that it may be the starter itself. I suppose there is a chance that it is stuck since it was sitting for awhile before I purchased it. I have never had to work on a starter before. Any tips on getting started (haha) would be much appreciated. Thanks!
#2 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted May 02, 2011 - 04:16 PM
Have you checked to make sure that power is getting to the started? If there is,I would remove the started and bench test it.
Here is a dumb question,are you sure the engine is not stuck ?
Also,welcome to the forum,glad to have you with us.
#3 Bolens 853 OFFLINE
Bolens 853
  • 5 Thanks
  • 34 posts
Posted May 02, 2011 - 04:37 PM
Check your battery maybe it needs charged.
#4 dadork OFFLINE
dadork
  • 3 Thanks
  • 29 posts
Posted May 02, 2011 - 05:17 PM
Yeah, I agree with 853, sounds like a weak battery.
#5 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1082 posts
Posted May 02, 2011 - 05:46 PM
Welcome to forum!!! Try jumping it and if that doesn't work then you might have a solenoid problem.
#6 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 03, 2011 - 06:59 AM
Just to clarify things... The original engine for this tractor is a Tecumseh..... Is that what you have in there?
#7 erbucky OFFLINE
erbucky
  • 3 posts
Posted May 03, 2011 - 07:37 AM
Yes, it is the original engine. I had tried hooking the battery up to the charger, it showed full charge. To be on the safe side I did try jumping it as well, same result. Last night I did hooked up a 12v tester to the cable running to the starter and had no power getting there. Since the same problem was occurring with both the old and new solenoid I am now working on the assumption that the cable from the solenoid to the starter is bad. Unfortunately it will have to wait a few days as I am heading out of town. Thanks for all the help so far!
#8 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 03, 2011 - 08:33 AM
Sounds like your on the right track. Keep us updated
#9 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted May 03, 2011 - 09:10 AM
:ditto:
