* * * * * 1 votes
My newest Diamond in the Rough!
110 johnson loader round fender attachment
41 replies to this topic
#16 Trav1s ONLINE
Trav1s
  • 3,509 Thanks
  • 4,492 posts
Posted March 20, 2016 - 02:30 PM
Excellent save!  I have faith in you and know you can save this one.
#17 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 20, 2016 - 02:34 PM
Here are pictures of my own:
Edited by johndeereelfman, March 20, 2016 - 02:35 PM.
  • Bolens 1000, Alc, Texas Deere and Horse and 2 others have said thanks
#18 Bolens 1000 ONLINE
  • 15,263 Thanks
  • 18,229 posts
Posted March 20, 2016 - 02:38 PM
The tractor itself looks pretty bad but the loader looks alright, the cylinders look clean an non pitted from the pics
#19 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 20, 2016 - 02:42 PM
A couple more:
  • Bolens 1000, olcowhand, Texas Deere and Horse and 1 other said thanks
#20 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 20, 2016 - 02:55 PM
The top right picture in my last post of pictures is of the dump cylinder. It's the worst of all of the cylinders. Pretty sure it won't be salvageable and will need to have a new rod machined. You are correct though Brian, for the most part, the loader really isn't in that bad of shape. The bucket is bent in the one corner, but I think if I add heat to it, it can be straighten out. Should be an interesting project nonetheless.
#21 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 20, 2016 - 02:57 PM
Well you just keep on having that faith Travis, because at this point, you have a whole lot more faith in me then I do!  :smilewink:  :thumbs:
  • Trav1s said thank you
#22 TomLGT195 OFFLINE
TomLGT195
  • 4,010 Thanks
  • 2,881 posts
Posted March 20, 2016 - 03:26 PM
As with all the projects  I've seen you do , this one will probably turn out like the rest. Beautifully restored and correct as possible. Great find, and good luck with the restore. I'll be following that.
Don't forget you only have one month to get a tractor ready for plow day!   :poke:  I pulled mine in the garage today to get started.
  • MH81 and johndeereelfman have said thanks
#23 MH81 OFFLINE
Posted March 20, 2016 - 09:20 PM
Troy,
That's a nice find. Can't wait to see it in action. Shame you can't keep them together, but understand why not.
  • Texas Deere and Horse and johndeereelfman have said thanks
#24 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 20, 2016 - 09:29 PM
Yes Alan, I hate to break them apart as well, however I have another '66 110 that would be willing to step up to the plate and take on this loader. At least the replacement 110 will be of the same year as the old one, so I guess the set won't be broken too bad.
#25 MH81 OFFLINE
Posted March 20, 2016 - 09:30 PM
The other one has wide tires?
#26 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 21, 2016 - 06:26 PM
As stated, this loader 110 should have 6-12 bar treads on the rear, but have been replaced with 23x8.50-12 rears at some point. The fronts on this tractor are the originals, but as you can see, are very worn and bad. The replacement '66 110 that I'll more than likely use, also has a narrow wheel package all the way around, however the fronts will be a studded or sometimes called a traction tire, on the front. The studded front tires I think would have actually worked better for biting into the ground for a loader use.
I've actually given thought about switching the serial plates, as both the original tractor and the replacement tractor are identical, other than condition, but I don't really know if I want to go that route, as it feels dishonest.
  • MH81, wvbuzzmaster, KennyP and 1 other said thanks
#27 MH81 OFFLINE
Posted March 21, 2016 - 06:31 PM
Maybe you could just change the frame and keep the serial with the engine, tranny and tins?
  • KennyP and johndeereelfman have said thanks
#28 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 21, 2016 - 06:56 PM
Good thinking Alan. I like it!  :thumbs:
#29 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted March 21, 2016 - 07:09 PM
That was my suggestion Troy, find another frame and rebuild the tractor back to original.
Lots of work ahead of you, but I know it will turn out great like all the other you have done !!!
#30 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 21, 2016 - 07:32 PM
Thanks Brian. I think I'm going to go with the ideas of you and Alan. I really like it, and if able to get away with just changing the frame out, then it will still feel like the pair are still together. I've been thinking about adding a set of headlights and a tail light to the tractor, but I don't think I will. I'm just going to restore this pair together and leave them as found, no headlights or tail light, no added accessories, and no hubcaps. A package like this doesn't come along everyday, and to find a pair like this that were bought together, is kind of special.
And by the way Brian, it's so good hearing from you again! Miss you Brother.  :thumbs:
  • MH81, Alc, Texas Deere and Horse and 3 others have said thanks
Also tagged with one or more of these keywords: 110, johnson loader, round fender, attachment
