$50 birthday present
35 replies to this topic
#31 Trav1s OFFLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted May 12, 2016 - 04:54 PM
I'd put my money on bad grounds.  Is the solenoid making good contact with the body?
  • KennyP and easternharvest have said thanks
#32 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted May 12, 2016 - 06:09 PM
I'll agree with that!
  • easternharvest said thank you
#33 easternharvest OFFLINE
easternharvest
  • 155 Thanks
  • 140 posts
Posted May 12, 2016 - 09:11 PM
Take a analog or digital VOM an check for voltages on the solenoid, when it should be none
So if I have voltage when ignition is in off position then faulty ignition switch correct?
#34 easternharvest OFFLINE
easternharvest
  • 155 Thanks
  • 140 posts
Posted May 12, 2016 - 09:13 PM
I haven't taken the solenoid off yet so that could definitely be the problem... I always overlook the obvious! Thanks for keeping on track guys!
#35 JD318420 OFFLINE
JD318420
  • 65 Thanks
  • 97 posts
Posted May 12, 2016 - 10:35 PM
Yeap if key switch off an still voltage (key switch has internal short) or something else is shorted putting voltage on solenoid.
#36 Trav1s OFFLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted May 13, 2016 - 07:05 AM
When I rebuilt my 120 I had a similar problem...
