* * * * * 1 votes
White GT1855 engine backfire
19 replies to this topic
#1 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted March 18, 2016 - 10:15 PM
From another post(oh no), the fire damage is repaired. Replaced stator, coil, plugs and carburator. Still the thing is backfiring through the exhaust, varying at different rpms. I adjusted the only adjustment on the carb to no avail. It's a Briggs 422437-0667-01. I don't know what else to do.
Any suggestions?
Thanks
  • chieffan said thank you
#2 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,459 Thanks
  • 4,577 posts
Posted March 18, 2016 - 10:42 PM
Sounds like a flywheel key issue.
  • boyscout862 and chieffan have said thanks
#3 GWest OFFLINE
GWest
  • 555 Thanks
  • 507 posts
Posted March 19, 2016 - 05:20 AM
Is it possible you have an exhaust valve not closing 100% at times?
Marvel Mystery oil in the fuel will lubricate the valve stems.
Garry
#4 chieffan ONLINE
  • 11,346 Thanks
  • 7,106 posts
Posted March 19, 2016 - 06:29 AM
First thing I thought of too.
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted March 19, 2016 - 08:07 AM
Worn keyway
#6 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted March 19, 2016 - 09:07 AM
Probably wishful thinking, but I will get some Marvel today! If the key way is worn, then that means new flywheel?
Thanks
#7 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,459 Thanks
  • 4,577 posts
Posted March 19, 2016 - 09:18 AM
Usually a new key will fix it, they are designed to fail before damaging the fly wheel or shaft. Don't be fooled if the key looks fine, just a little shear will affect the timing. This key was the cause of this engine mis-fireing.
  • Auburn David said thank you
#8 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted March 19, 2016 - 09:27 AM
Good info! Not what I wanted to hear since it's all back togefher, but I will order a new key.
Thanks
#9 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted March 28, 2016 - 10:33 AM
Finally I have some time to look at the tractor. I see a pulley key on outer end of the crank and a flywheel key that looks like it's on the inside of the engine. Which one do you think is worn? If the one I need is the internal one, that is beyond m comfort zone. What do you think?
#10 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,459 Thanks
  • 4,577 posts
Posted March 28, 2016 - 01:23 PM
It will be the flywheel key, hopefully it will be easy to remove sense you had it apart recently.
#11 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted March 28, 2016 - 04:32 PM
The tech at the parts store agreed. He said the diagram makes it look internal, but it's the one at the flywheel.
Hopefully I can get on it tomorrow.
Thanks
#12 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted April 03, 2016 - 10:23 AM
Well, well well.
Replaced the flywheel key, no change. Still backfiring and missing. New carb, coil, stator and plugs and high speed carb adjustment. I don't know what else to do so I'm going to try to find someone locally who can work on it.
#13 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted April 05, 2016 - 07:39 AM
Finally got a compression tester, 95 on left bank 0 on right bank. Heads are coming off. I will let you know what he finds (about 4 weeks)
That work is beyond my knowledge base.
#14 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted April 12, 2016 - 09:47 PM
Well, the master tech called and said the block is ruined. It is no longer available so a repowered is my only option. He does not have one so I will try to sell it as is with all the attachments on craigslist. I don't want to put anymore money into it.
Thanks for all your help.
#15 KennyP OFFLINE
  • 40,899 Thanks
  • 47,099 posts
Posted April 13, 2016 - 06:40 AM
A option is to find the vertical shaft version of the 422437. The crank in it can be shortened to the horizontal specs and converted to a horizontal! I have one here I need to finish putting together that way.
I think that would be the 422700 series engines. I have researched the part #'s and they are the same for the block, rods, & pistons! Just have to use the horizontal pan and front engine cover.
  • Rock farmer said thank you
