Flo-jet carb help ?
6 replies to this topic
#1 Tecumseh power ONLINE
Tecumseh power
  • 1,420 Thanks
  • 1,082 posts
Posted March 17, 2016 - 08:43 PM
OK guys, I have an updraft flo jet on an 8hp briggs. I got a new needle and seat from bolens 1000, put all that good stuff in. Checked the float for sinking and holes. Have the float adjusted good . I am having fuel leaking out of the end of the intake . It is leaking around where the emulsion tube seats. What are you guys tricks for getting them to seal. I wouldn't care if it was mine I would just shut the gas off . Because it doesn't leak when running. But I'm doing it for someone else. Thanks.
Edited by Tecumseh power, March 17, 2016 - 08:44 PM.
#2 drbish ONLINE
drbish
    Collecter
  • 1,464 Thanks
  • 1,295 posts
Posted March 18, 2016 - 04:49 AM
Page 25 covers this topic.http://gardentractor...pdate-seminar/
  • boyscout862 and Tecumseh power have said thanks
#3 GWest OFFLINE
GWest
  • 512 Thanks
  • 464 posts
Posted March 18, 2016 - 05:38 AM
Loctite or Permatex have a Teflon paste thread sealer in a small bottle with a brush.
Have had good luck applying that product to the tapered seat of the nozzle with a toothpick.
Garry
  • limebuzz, karel and Tecumseh power have said thanks
#4 chieffan ONLINE
  • 8,368 Thanks
  • 5,790 posts
Posted March 18, 2016 - 07:36 AM
I have a float in Walbro that I have checked 3 times and soldered twice.  Hot water check and all.  It will sit for 3 or 4 hours with the gas on and no leak.  Then start to use it and it starts running out the intake.  Check that float again.  I bet there is a crack in it some place that is real hard to find.  I ordered a new float but that is about a thing of the past also.
  • Tecumseh power said thank you
#5 Tecumseh power ONLINE
Tecumseh power
  • 1,420 Thanks
  • 1,082 posts
Posted March 18, 2016 - 09:30 AM
Garry
I'd it like the Teflon pipe dope they make?
#6 GWest OFFLINE
GWest
  • 512 Thanks
  • 464 posts
Posted March 18, 2016 - 11:58 AM
It likely is. Fuel does not seem to bother it and looks like tape was used when you remove a fitting. In this application there is no chance of it getting to the holes in the nozzle.
Garry
#7 Tecumseh power ONLINE
Tecumseh power
  • 1,420 Thanks
  • 1,082 posts
Posted March 18, 2016 - 12:30 PM
I did get it what I did was chuck some questions tips in my drill and put rubbing compound on them and just polished the heck out of where it seats
