Jeep trailer wiring, will Diodes fix this?
30 replies to this topic
#1 TAHOE ONLINE
TAHOE
  • 8,338 Thanks
  • 5,820 posts
Posted March 17, 2016 - 09:02 AM
I am trying to "rig" up a trailer wiring harness on my son's Jeep 2000 Cherokee, but never encounter separate turn and brake light circuits like this one has.
Before everyone says go by the plug in convertor kit, I am cheap so trying to do this DIY. Diodes are a couple dollars at most where the convertor is about $20
Since I have 2 separate circuits that need to feed the single brake/Turn signal circuit of the trailer, can I wire in a diode in each circuit coming off the Jeep and then into one going to trailer?
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted March 17, 2016 - 09:12 AM
Not exactly.
I did almost that (used bridge rectifier) the trouble was the brake light will over ride the turn signal.
It got me by for the two years I had it, but I was always hesitant.
Another thing you must consider is if the vehicle has computer controlled brakes. My Freestar does and I had to have my son Ryan (electronics engineer) build a controller using SCR's, diodes and current limiting resistors.
Had most of the parts at the house, otherwise it wouldn't have been worth building.
  • Alc, jpackard56 and TAHOE have said thanks
#3 toppop52 ONLINE
toppop52
  • 5,607 Thanks
  • 4,949 posts
Posted March 17, 2016 - 09:16 AM
Listen to your friends, buy the box, my best friend has a degree in electronic engineering and is an excellent mechanic/electrician. My son has a stack of degrees in computer electronics as well as software, etc... They both bought the box.
  • Gtractor, MH81, Alc and 3 others have said thanks
#4 TAHOE ONLINE
TAHOE
  • 8,338 Thanks
  • 5,820 posts
Posted March 17, 2016 - 09:17 AM
Not exactly.
well poop, not what I wanted to hear.
#5 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted March 17, 2016 - 10:04 AM
I know how you feel,,   I'm a cheep skate my self.. :smilewink:   But I think the plug and play, is the way to go.. It will take out the guessing out of the equation,  and they will not corrode as fast as a jerry rig and give you problems down the road..
        sorry,,,,,,
  • TAHOE said thank you
#6 MH81 OFFLINE
  • 29,979 Thanks
Posted March 17, 2016 - 10:09 AM
I should do a write up on the one he did for me.
It was a Father Son project as well, so worth something there too.
  • Alc and TAHOE have said thanks
#7 MiCarl ONLINE
MiCarl
  • 2,219 Thanks
  • 1,129 posts
Posted March 17, 2016 - 11:37 AM
I made one once.  Used relays.  Cost about $30 to build........
Buy the box.
  • MH81, Alc and TAHOE have said thanks
#8 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,616 Thanks
  • 2,913 posts
Posted March 17, 2016 - 12:00 PM
My neighbor just had to put a new computer in his jeep from trying the same thing. $20.00 looks better than the $390.00 he just paid for a used computer and labor to install. JM2CW! Good luck.        Roger
#9 chieffan ONLINE
  • 11,797 Thanks
  • 7,290 posts
Posted March 17, 2016 - 12:46 PM
If you put the box on your Jeep, no other vehicle with separate turn signals can pull the trailer unless they have the box also.
Add a pair of amber clearance lights to your trailer and use them as your turn signals.  Separate plug to the Jeep.  Regular vehicle with combination brake/turn just use the regular plug and forget the one to the amber lights.
  • Alc and Sawdust have said thanks
#10 TAHOE ONLINE
TAHOE
  • 8,338 Thanks
  • 5,820 posts
Posted March 17, 2016 - 12:51 PM
All my trailers are the standard wiring, I already have a convertor box on the Jeep Liberty, guess the Cherokee will get one. A lot easier than changing the trailers. We maybe getting a Dodge Durango also soon so I guess it may need one too, if it has a trailer hitch.
All my family is driving Dodge junk, I'm the only GM left    :( I gotta work on it all :wallbanging:
#11 dodge trucker ONLINE
dodge trucker
  • 2,914 Thanks
  • 3,536 posts
Posted March 17, 2016 - 01:09 PM
the Durango doesnt have seperate brake/turn like the Cherokee.  I have had 2 Cherokees (an 01 and a 97)  and currently have an 01 Durango  and yes for $20 that converter/trailer light wiring plug is definitely plug n play, installed them on both my Cherokees)
Incidentally I got the Durango because we wanted Cherokee #3 but couldn't find one with a rust free body AND under 200K miles for less than $6 grand at the time.  (so I wound up with a rust free Durango from the South with  214K on it instead, for like 1/3 of the price of another Cherokee)     wife's daily  now with 256K and climbing, I just dropped off a spare and disassembled 360 ("5.9") at the machine shop this morning, as a matter of fact, to get ready for a swap "just in case"
#12 Mtypython OFFLINE
Mtypython
  • 374 Thanks
  • 352 posts
Posted March 17, 2016 - 04:03 PM
My 03 blazer ran the wires for the turn signals to thier respective sides and the brake wire to one brAke light and the running lights to the wire ,just pull the light assemblies out and use splice connectors, no problems at all
#13 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted March 17, 2016 - 06:22 PM
Here is another ball-buster......a friend told me his Jeep wiring harness (from factory) is different than his wife's Jeep Cherokee (factory wiring harness).
He has to have 2 different adapters for the 2 Jeeps he has!
#14 toppop52 ONLINE
toppop52
  • 5,607 Thanks
  • 4,949 posts
Posted March 17, 2016 - 06:29 PM
The convertor goes on the vehicle, it had no effect on the trailer wiring, any vehicle can tow the trailer with 4 flat plug.
#15 MH81 OFFLINE
  • 29,979 Thanks
Posted March 17, 2016 - 06:45 PM
Most of the new vehicles are "new and improved" to the point that the computer senses a change in current and won't light the light.
Even the wrong bulb in a pinch can cause it.
  • esbbent and jpackard56 have said thanks
