Looking for Wheels for My Compact Tractor
6-12 mahindra kubota 9.5 x 16 ag tire
18 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted March 16, 2016 - 10:07 PM
I have a Mahindra Max25 4x4 compact tractor that has the industrial type tires and wheels. I'd like to put Ag tires on it, but that requires a different wheel size for both the front and rear.
Mahindra specifies a 9.5 x 16 rear tire, and a 6-12 front tire for the tractor.
The rear wheel has a 6 hole on 6" bolt pattern, which I believe is the same as Bolens Large Frames, most Kubota CUTs, etc. The front wheel is a 5 on 4 1/2" patern with an approx. 3 1/8" pilot, which is what is used on most GT rear wheels.
The rear wheels are fairly common and available, but I can't find front wheels--I have a FEL with a 900 lb lift capacity, so I don't think GT wheels would work.
Does anyone know of another tractor that would have the size and bolt pattern I need for the front? (I've checked with Nebraska tire--they have the rear wheels and tires and the front tires, but not the front wheels)
Any help would be appreciated.
Smitty
  • nitail11 said thank you
#2 Alc ONLINE
  • 7,132 Thanks
  • 7,533 posts
Posted March 17, 2016 - 05:30 AM
Would a trailer type wheel work ?
http://www.easternma...im?options=cart
  How wide of a wheel would you need ?    The offset might be odd of a 4x4 too
Edited by Alc, March 17, 2016 - 05:32 AM.
  • Utah Smitty said thank you
#3 chieffan ONLINE
  • 10,962 Thanks
  • 6,946 posts
Posted March 17, 2016 - 06:45 AM
Check with one of the many tractor salvage places.  West Kentucky Parts has a bunch of Kubota parts.  Also try Wengers of Myerstown in PA.
  • Alc and Utah Smitty have said thanks
#4 glgrumpy OFFLINE
  • 8,746 Thanks
  • 7,983 posts
Posted March 17, 2016 - 07:02 AM
Aren't R-1 tires the same or close to Ag tires and made for big traction?  So, not understanding why you would change them??  Or is that NOT what you have as "industrial" tires?
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 17, 2016 - 07:23 AM
GL- Industrial Tires= Skid Steer type tires. Usually wider then equivalent height AG tires for most small tractors.
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted March 17, 2016 - 12:16 PM
The Mahindra is relatively new(here in the states) and I would be surprised if there are many salvaged yet.
If you check with a big tire shop you may find that you can get new aftermarket wheels nearly as cheap as you can find used?
An after thought, I remember that International built the Mahindra factory, with the agreement that they build Internationals compact for so many years and then it reverted back to the Mahindra Brothers.
So if you could find the International models closest in size, you may be able to find wheels off an International.
Edited by JD DANNELS, March 17, 2016 - 12:24 PM.
#7 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted March 17, 2016 - 06:44 PM
Thanks for your input. I need a 5 inch wide wheel, while all the trailer wheels I was able to find are only 4 inches wide.  Some do have some offset, but many are zero offset.
Smitty
#8 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted March 17, 2016 - 06:51 PM
The tires on my Mahindra basically have the same lug pattern as those used on skid steers, and are quite wide.  The rear is a 27 x 12.5-15, and the front is a 20 x 8-10. They don't work well in wet dirt or snow--just tend to pack up into a slick.
I tried to upload some pictures of them, but they failed... not sure why. Anyway....
The ag tires Mahindra specs out are a 9.5-16 which is 33 inches in diameter, and 6-12, which is 23 inches in diameter.  The ag tires are narrower, which will work better in my garden for creating raised beds, and will also give me 1 1/2" to 2" increased ground clearance. They also have a deeper tread and mud and snow won't stick as readily to them.
Regards,
Smitty
Edited by Utah Smitty, March 17, 2016 - 07:01 PM.
#9 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted March 17, 2016 - 07:02 PM
That's a great idea!!  I've found some Kubota tractors that use the same size wheels, but they have a 6 bolt hole pattern, or a 4 bolt hole pattern.
Smitty
#10 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted March 17, 2016 - 07:04 PM
So, I found some 5x12 wheels with the right bolt hole pattern on eBay.  I'm pretty sure they're made for garden tractors.  I've looked at the thickness of the wheels on my Mahindra, and the GT wheels seem to be about the same gage... I'm wondering if it might be worth the chance to try some of the GT wheels and see how they hold up????
Smitty
  • backwoods said thank you
#11 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted March 17, 2016 - 09:16 PM
Okay, here's another question regarding swapping tires.
The tires currently on my Mahindra Max 25 have a diameter of 27" on the rear and 20" on the front, or a ratio of .741.  My Mahindra manual says the ag tires are a 9.5-16 rear (33" diam.) and 6-12 front (22-23" diam. depending on mfr).  The ratio for these tires is .697--quite a difference.
If I get a 7-12 (24.5" diam) for the front, the ratio will be closer to what is on it now-- .742
I'd like to get the taller front tire--a little more ground clearance, and hopefully a little better weight-carrying capacity.
Do you think it will be a problem to use the 7-12 in lieu of the 6-12??
Thanks,
Smitty
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted March 18, 2016 - 09:57 AM
I am assuming the Mahindra is 4 wd. I do not remember the percentage, but if the wheel tires on both axles are mismatched by much it can bind the gears and tear them out.
  • limebuzz said thank you
#13 bh115577 OFFLINE
bh115577
  • 443 Thanks
  • 240 posts
Posted March 18, 2016 - 10:28 AM
Go to your Kubota dealer and tell them what you are trying to do. If the lug pattern is the same as your machine they can order tires and wheels through whole goods at crazy low prices. I believe you need to speak with a salesman instead of the parts guys to get whole goods pricing though. Last post I read on a Kubota site was the price of 4 tires and wheels was lower than just a single rear tire through parts.
#14 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted March 18, 2016 - 02:16 PM
It is a 4x4, but the tires that Mahindra specs for Industrial versus what Mahindra specs for Ag tires have a significantly different ratio. .697 to .741--
I'm not sure which is the best ratio to follow. The Age tires has the higher number...
Smitty
#15 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted March 18, 2016 - 02:20 PM
That's a good idea--several Kubotas have the same size rear tire and wheel with the same bolt pattern, but I haven't found any Kubota or JD/Yanmar with 5 bolt holes on the front.
Smitty
Also tagged with one or more of these keywords: 6-12, mahindra, kubota, 9.5 x 16, ag tire
