I am wondering if there is an adjustment for the little arm between the primary and secondary plates. I believe it keeps the secondaries from opening to soon when opening the primaries. The secondaries are not suppose to start opening until the primary plates are opened to about 40 degrees. This is a vacuum operated secondaries. Thanks for any ideas.
"Vacuum" assisted carb. IF everything is working correctly the carb will work without that arm being there. If it's opening too early you need a stiffer spring in the dashpot
In one word--no-- no adjustment is required or recommended on the rod , although many hot-rodder's do try and tweek them thinking they may find some magical horse power-but its not going to happen--As previous posters said its there to hold the secondary closed and
to prevent it from overriding the primary plates in the case of high vacuum at part throttle opening-- kind of a safety thing .
Great, thanks for the information. It is holding the secondaries closed while the primaries are closed. Yes, someone welded the little rod together. That's why I was wondering about adjustment.
Noel
Related Threads
Garden Tractor Forums
951.2K posts
49.2K members
Since 2010
