Brinly Hardy Tandem Disc
32 replies to this topic
#16 Sawdust ONLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted March 26, 2016 - 08:59 AM
I agree too about what OB was saying & others. These things can get a guys head spinning. I probably won't be using them for awhile now that I already tilled the garden. I want to take them apart to clean them up, prime, paint & grease the axles. I'm impressed with the disc not much wear sat all on them & the axles look left alone & maintained. Thanks everyone for your input I really appreciate it. This is what makes GTtalk such a great place to be apart of.
Edited by Sawdust, March 26, 2016 - 09:00 AM.
  • MH81, propane1 and CanadianHobbyFarmer have said thanks
#17 toppop52 OFFLINE
toppop52
  • 5,532 Thanks
  • 4,899 posts
Posted March 26, 2016 - 09:20 AM
I bought mine, one slightly used for $100, one never used for $100, but had to drive a hundred miles for it. I grew up on a farm so I knew which way to turn them. :D
  • Sawdust said thank you
#18 propane1 ONLINE
propane1
  • 9,438 Thanks
  • 4,383 posts
Posted March 26, 2016 - 10:22 AM
I have a set of tamden disks. I leave mine losse in the middle so they will have some float. You will not have any up and down movement, or side to side, between the two if they are solid, so one or the other disk may not be making much ground contact if they have no float. Think of a set a reel mowers, they have float so they will cut uneven landscapes. Same thing applies to disks, in my mind..
Noel
#19 toppop52 OFFLINE
toppop52
  • 5,532 Thanks
  • 4,899 posts
Posted March 26, 2016 - 04:12 PM
I just use a pin between mine and I put weights on both. When I lift mine, the rear unit sags quite a bit, but the tear up some dirt!
Edited by toppop52, March 26, 2016 - 04:15 PM.
#20 dropped82 ONLINE
dropped82
    Nut Case
  • 2,738 Thanks
  • 1,903 posts
Posted March 26, 2016 - 10:26 PM
IIRC, the brinly factory 3 point dual disc is mounted rigid. You essentially just made one. Other than turning your discs the correct way, lots of weight will be your friend. What would really help is using it behind a machine with down pressure also.
Eric
  • limebuzz and Sawdust have said thanks
#21 Sawdust ONLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted March 31, 2016 - 09:08 AM
Guys I don't want to drag this topic on & on but the curiosity is killing me. I reversed the rear tandem disc as mentioned. I locked the two tandems as one using two bolts in the middle of the pivot area. I tried it out & was very happy with it this way. The disc obviously worked a lot better mounted the right way. Wanting to try all options I took one of the bolts out & loosened the other to allow it to pivot & off I went...again. I will admit it seemed to work better this way allowing as mentioned the rear unit to float better as Noel mentioned. I don't like towing versus using a hitch with a lift. This Sears SS15 is a manual lift but some have added an electric lift...maybe later. I want to get a hitch made up for one of the other hydraulics I have. Thanks so much again for your interest...now next will be the painting but later.
We got a few rows of onions out too.
  • DH1, limebuzz, MH81 and 4 others have said thanks
#22 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted March 31, 2016 - 09:23 AM
Good stuff glad you got it working  :thumbs:
#23 MH81 OFFLINE
  • 29,978 Thanks
Posted March 31, 2016 - 11:33 AM
:thumbs: Now that will work!
Glad it's making you happy.
#24 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted March 31, 2016 - 02:04 PM
Good to hear that you got it working for you.
Jim
#25 dropped82 ONLINE
dropped82
    Nut Case
  • 2,738 Thanks
  • 1,903 posts
Posted March 31, 2016 - 04:44 PM
Does your 990 have a 3 point? Seems to me it would be the ideal candidate for handling the disc. Especially since the disc was modified to mount on a 3 point.
Eric
#26 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted March 31, 2016 - 08:12 PM
Brinly stated that the sleeve hitch tandem disc was not designed to be lifted.
I don't remember where I saw it, but will look around to fine where they stated that,
  • Sawdust, toppop52 and CanadianHobbyFarmer have said thanks
#27 toppop52 OFFLINE
toppop52
  • 5,532 Thanks
  • 4,899 posts
Posted March 31, 2016 - 08:20 PM
It hasn't hurt it yet, but I'll keep an eye on it.
  • Sawdust and propane1 have said thanks
#28 propane1 ONLINE
propane1
  • 9,438 Thanks
  • 4,383 posts
Posted March 31, 2016 - 09:05 PM
This is my set up, it's lifted by the sleeve hitch. I only put weight on the front disks.
Noel
  • Sawdust and holdenboy1960 have said thanks
#29 Sawdust ONLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted April 01, 2016 - 09:19 AM
Eric
No Eric I don't have a hitch for the 990 yet. I have the metal & drawings of the original but just haven't had the time to make it yet. I plan on my 990  being my work horse. Thanks
#30 dropped82 ONLINE
dropped82
    Nut Case
  • 2,738 Thanks
  • 1,903 posts
Posted April 01, 2016 - 08:02 PM
If you need any pics, I have one on my 990. Would be happy to help with what I can.
Eric
