Wanted
Cub Cadet Snow Plow Mount
2 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted March 15, 2016 - 01:06 AM
Need a snow plow mount for Cub Cadet front blade. The piece I need is the triangle shaped part between blade and mounting subframe, as mine is broken beyond repair. The price was right for the rest of it so I bought it. Let me know what you have. The rest of the parts on this are ok since I had found a blade only recently to replace the rotten one that came with.
Casey
#2 glgrumpy ONLINE
  • 8,618 Thanks
  • 7,926 posts
Posted March 15, 2016 - 07:30 AM
Thot cubs pretty much have two frames, look same, diff sizes is all. All one piece from the blade pivot back to tractor? Kinda long, two arms that hook on bar at back of frame and two parts to clip into the front slots. No parts then??  OR, am I looking at later models only??  Was told Wide frame and Narrow frame was what to look for. Blades are pretty much all the same.
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted March 15, 2016 - 10:30 AM
They are all the same except the tractor mounting subframe. I need the pivot mount that is the next part from that subframe.
