Pickup trans
13 replies to this topic
#1 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 369 Thanks
  • 505 posts
Posted March 14, 2016 - 11:18 AM
I jest got my pick up moving and i don't got revers on my trans and it is a 78 350 amoadic chevy tranmishion
Edited by pick-to-stone, March 14, 2016 - 11:20 AM.
#2 TAHOE OFFLINE
TAHOE
  • 8,296 Thanks
  • 5,797 posts
Posted March 14, 2016 - 11:49 AM
I would pull the pan and check the internal linkage. There is an S hook that attaches to the "rooster comb" that goes to the manual valve, it could have popped off. If not, then your reverse clutches are probably fried
#3 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 369 Thanks
  • 505 posts
Posted March 14, 2016 - 12:04 PM
Thats going to suck
#4 DougT OFFLINE
DougT
    Dog Approved
  • 7,110 Thanks
  • 5,075 posts
Posted March 14, 2016 - 01:42 PM
If the internal linkage fell apart, you would be in drive all the time. If you can get neutral then it probably isn't the link. The low/rev and the direct clutches have to apply to go backwards. If you have good 3rd then the low/rev is bad. A test for that will be to see if you have good engine braking in manual low.
#5 toppop52 OFFLINE
toppop52
  • 5,532 Thanks
  • 4,898 posts
Posted March 14, 2016 - 01:50 PM
The good news is t 350's are cheap.
  • bh115577 said thank you
#6 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 10,846 Thanks
  • 6,342 posts
Posted March 14, 2016 - 02:25 PM
Is this in your step side in your other thread?
Good time to upgrade to a nice "built" transmission.  Jegs had some for 700-800 bucks that would handle up to 450-500hp.  Perfect amount of HP for that truck!
  • pick-to-stone said thank you
#7 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 369 Thanks
  • 505 posts
Posted March 14, 2016 - 02:54 PM
Yes but i can not chang the truck was coustumly built
#8 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 369 Thanks
  • 505 posts
Posted March 14, 2016 - 04:04 PM
I got 4 quarts in the trans right now if add one more do you guys think it will work
#9 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 369 Thanks
  • 505 posts
Posted March 14, 2016 - 04:07 PM
And thanks but i don't need horse power for this one its jest going to become a show car
#10 glgrumpy OFFLINE
  • 8,803 Thanks
  • 8,009 posts
Posted March 14, 2016 - 07:23 PM
Wait! Four qts of fluid is minimal in an automatic!  Has this been all drained out including the convertor?  Will take like 13qts I think  or see a manual. Use the dipstick to see if enough is in it. Check in N most times at idle while running. Don't over-fill past the full mark or it foams and causes other problems. If not enough fluid in it to begin, then it won't work right till it is full or at least a minimal qt low.
#11 poncho62 ONLINE
poncho62
  • 2,110 Thanks
  • 1,779 posts
Posted March 14, 2016 - 07:25 PM
Have you checked the trans fluid on the dipstick?
Start truck up, put in each gear, put in park and read the level on the dipstick. If its low, add until it hits the full mark. Those transmissions take 9-11 quarts from empty.
#12 UncleWillie OFFLINE
  • 16,252 Thanks
  • 8,969 posts
Posted March 14, 2016 - 07:52 PM
4 quarts is a good start. If that is all that is in it keep adding.
#13 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 369 Thanks
  • 505 posts
Posted March 15, 2016 - 12:54 PM
Had to fill it its been sitting for so meny years it didn't have any in it
#14 DougT OFFLINE
DougT
    Dog Approved
  • 7,110 Thanks
  • 5,075 posts
Posted March 15, 2016 - 04:59 PM
Like Poncho says, use the dipstick, don't guess. Adding 1 quart overfull won't hurt anything if you're unsure of your dipstick being the right one.
