Sears 16/6 Twin
39 replies to this topic
#31 bbuckler OFFLINE
bbuckler
  • 2,346 Thanks
  • 2,129 posts
Posted April 23, 2016 - 04:53 PM
Got the deck fixed but I can't get the carb adjusted right. It stalls out under a heavy load.
#32 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted April 23, 2016 - 08:30 PM
Timing can cause it too.
  • bbuckler said thank you
#33 bbuckler OFFLINE
bbuckler
  • 2,346 Thanks
  • 2,129 posts
Posted April 23, 2016 - 10:36 PM
Going to try soaking the carb again in carb cleaner this time. My dad had some diesel so we tried that the first round.
#34 bbuckler OFFLINE
bbuckler
  • 2,346 Thanks
  • 2,129 posts
Posted April 26, 2016 - 11:13 AM
Got it running and mowed the field. Only problem so far is it smoke a little at low throttle.
#35 bbuckler OFFLINE
bbuckler
  • 2,346 Thanks
  • 2,129 posts
Posted April 30, 2016 - 08:17 PM
I hope I don't jinks it but that 16/6 starts up everytime with out any problems
  • MH81 and TAHOE have said thanks
#36 bbuckler OFFLINE
bbuckler
  • 2,346 Thanks
  • 2,129 posts
Posted May 12, 2016 - 10:48 AM
I forgot to share that the 16/6 twin got a three point thanks to Andy.
#37 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted May 12, 2016 - 12:20 PM
Cool, One of the good ones too.
#38 bbuckler OFFLINE
bbuckler
  • 2,346 Thanks
  • 2,129 posts
Posted May 15, 2016 - 07:29 PM
One thing that was found that it is running rich Andy tried adjusting the setting. The float it right but I saw something about brass floats needing assist spring,
#39 bbuckler OFFLINE
bbuckler
  • 2,346 Thanks
  • 2,129 posts
Posted June 19, 2016 - 04:23 PM
I got new bearings coming for the deck but I don't think I will need to mow for awhile. It looks like the pasture is done growing for the summer.
#40 JiminRI OFFLINE
JiminRI
  • 76 Thanks
  • 73 posts
Posted June 19, 2016 - 10:25 PM
I replaced the fiber float in my SS-16 with a brass float - no assist spring. I adjusted it for 1/8 inch clearance per the manual - no problems. I did see articles on the assist spring - if you want to try it, this is the link for the spring referenced - http://www.casegarde...m/14sponfl.html
Good luck,
Jim
