b&s 20hp vtwin
14 replies to this topic
#1 1965vic OFFLINE
1965vic
  • 10 posts
Posted March 09, 2016 - 08:13 PM
Trying to get it running, valves 4 on intake 6 on exhaust, cleaned fly&coils battery &cables.when i spin flywheel get a wheesing sound.just can't seem to get it.any help?
#2 boyscout862 ONLINE
  • 11,444 Thanks
  • 8,473 posts
Posted March 10, 2016 - 06:21 AM
Welcome to GTT. We would like to help but you will need to give us more detailed information. Try the manual in our Manuals Section, it should have a trouble shooting section. It will tell you step by step how to figure out what is wrong. When asking questions, use pics and describe the problem in detail. Good Luck, Rick
#3 1965vic OFFLINE
1965vic
  • 10 posts
Posted March 10, 2016 - 04:13 PM
Will do.just got on fourm pictures as soon ad i figure how.
#4 1965vic OFFLINE
1965vic
  • 10 posts
Posted March 10, 2016 - 05:09 PM
I feel seriously challenged when a 12-15 yr old on youtube can rebuild this whole engine, and i cant even get it to run.
#5 jms180 OFFLINE
jms180
  • 1,220 Thanks
  • 1,403 posts
Posted March 10, 2016 - 06:32 PM
don't give up there are some very helpful folks here
#6 drbish OFFLINE
drbish
    Collecter
  • 1,464 Thanks
  • 1,295 posts
Posted March 10, 2016 - 07:06 PM
Where are you located in North Carolina,and also welcome to GTT,If you are close I would be more then
willing to help you out
#7 Rustysteele OFFLINE
Rustysteele
  • 261 Thanks
  • 82 posts
Posted March 11, 2016 - 07:27 PM
Try spraying carb cleaner (NOT ETHER!) into the carb without the air filter. If it fires, it`s a fuel issue, if it doesn`t, it`s ignition or compression. If it will run of carb cleaner, the fuel might be stale , clogged fuel filter, or a carb that needs cleaning. Let us know how you make out with it.
#8 1965vic OFFLINE
1965vic
  • 10 posts
Posted March 11, 2016 - 08:00 PM
Thurs night3/10 hooked juper cables to truck cause battery sticker says 9/12 tiny spark probably bad, but got to spin with NO plugs.plugs in 1/4turn.have not opened carb yet.cleaned tank lines to carb though.when spun first time with no plugs it spit bad gas.valves abj too many times
#9 1965vic OFFLINE
1965vic
  • 10 posts
Posted March 11, 2016 - 08:05 PM
Location charlotte/harrisburg near 485. Planning on going 2 lowes for battery with 410 ca.i think it would help.if this gets done then rewire back half of 96 yardmachine i burnt up trying to start last year.and yes i did not do preventive maintenance not incapable just put off.
#10 1965vic OFFLINE
1965vic
  • 10 posts
Posted March 11, 2016 - 08:24 PM
How to post pics?
#11 KennyP ONLINE
  • 34,249 Thanks
  • 43,371 posts
Posted March 12, 2016 - 08:08 AM
How to post pics?
:wave: Welcome to the forum! Check the link in my signature for pic help!
#12 1965vic OFFLINE
1965vic
  • 10 posts
Posted March 25, 2016 - 06:32 PM
#13 1965vic OFFLINE
1965vic
  • 10 posts
Posted March 25, 2016 - 06:33 PM
#14 1965vic OFFLINE
1965vic
  • 10 posts
Posted March 25, 2016 - 06:37 PM
#15 1965vic OFFLINE
1965vic
  • 10 posts
Posted March 25, 2016 - 06:49 PM
