PK Fel Hydraulic cylinders
5 replies to this topic
#1 Timehunter OFFLINE
Timehunter
  • 6 Thanks
  • 9 posts
Posted March 09, 2016 - 07:33 AM
I have been rebuilding my PK1612 and building a front end loader for it.
It has been sitting under a plastic tarp for over a year now I guess without
  me touching it.
Does anyone know the sizes of the hydraulic cylinders for the arms and bucket?
I am doing some horse trading and they will probably be bought at Tractor Supply.
Then I can go on to the pump.
I had one bucket built but made it a little too heavy duty and am going to have to build
    a lighter one.
Don't know if my old link to my pics. still works...
Any ideas on the cylinders?
#2 Alc OFFLINE
  • 6,884 Thanks
  • 7,459 posts
Posted March 09, 2016 - 08:38 AM
I know they made different loaders though the years , it might help if you can find the model # or  maybe someone will recognize  it from a picture . On my loaders bucket someone replaced a cylinder that is very close to the OEM one . are your cylinders missing that you can't measure ?
#3 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted March 09, 2016 - 09:17 AM
This gives some measurements.
#4 Timehunter OFFLINE
Timehunter
  • 6 Thanks
  • 9 posts
Posted March 09, 2016 - 02:07 PM
Tractorholic, the drawing Username has the link to is the one that I used in building mine.
I just extrapolated dimensions from it and built mine.
So, whatever cylinder diameter and length and rod diameter and length for the arms and bucket is
    the info that I am hunting for.
I know "about" what I need,...but..it sure would be nice to know the real sizes.!
#5 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted March 09, 2016 - 06:22 PM
If you look at the digram it gives you bore and stroke that is what you need. The measurements seem to be there you may just want to check it again. The stroke is the length of the piston and bore is the diameter.
#6 Timehunter OFFLINE
Timehunter
  • 6 Thanks
  • 9 posts
Posted March 10, 2016 - 07:55 AM
Yep
It is right there on the drawing.
It has been so long since I had anything to do with this project that I am going to have to refresh my memory on everything
  I had going on at the time I stopped. That should be fun....
Just with the deal-barter I just made I needed the info now so he can get the ball rolling on the cylinders.
I just might finish this project in the next 50 or 100 years!
That is what it seems like at times as I still have to get to the point of working on it again.
I hope in the very near future I can post some completed pictures!
Thank ya'll for the help!
  • Alc, KennyP and Username have said thanks
