Can anyone identify this hydraulic pump? I found it in some stuff my father had. He used to work at a IH/CC dealer. He worked on everything from CCs, farm tractors, semi trucks, to school buses. From what I can see, it resembles some Farmall & Lo Boy pumps. I was leaning towards Lo Boy, since it's yellow, but couldn't find a good match with a quick online search. Thoughts?
Are there no part numbers or I'd markings? Looks to be a two port rotary pump but any more than that I would need to put it on a test bench to check pressure and flow. That would only allow me to give you its output and capabilities. Why do you need to know, do you plan to use it or sell it? Maybe someone else has seen this particular unit and can help you out. From what I do see it looks relatively small but that may be perception, use a quarter or ruler for scale and it may help more.
It an't no garnden tractor pump we might be looking at smothing bigger and its not a lo boy nor tractor but i have sen this type of pump befor but i can't rember where
That's what I was talking about. The pump looks REALLY close to those, but the numbers a couple digits off. It looks to mount up the same, but the bolt/mounting ears are deeper on the one I have. Longer bolts would fix that. Would it be safe to say that they are interchangeable?
Shoot me a PM. I would like it to find a good home.
Related Threads
Garden Tractor Forums
951.2K posts
49.2K members
Since 2010
