Panzer T70 Resto-Mod
317 replies to this topic
#31 BowDown ONLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted April 28, 2016 - 01:35 PM
Frame rails leveled up and tacked to the rear end. Next up driveline placement. 2d7c5cc8dbcc183ba7bcf3c10ea891fe.jpg67cbff33ba04d22ab84ce352e8791615.jpgd6973a944d8e91ed3a0b57c894ba5507.jpga46d00d15135a1026a9b6da85ee7381c.jpg
  • Alc, Traill95 and holdenboy1960 have said thanks
#32 BowDown ONLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted April 29, 2016 - 10:26 AM
Hopefully I'll start laying out the driveline today during lunch! Stay tuned..
#33 BowDown ONLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted April 29, 2016 - 01:19 PM
Looks like it'll work! Have to clearance the gusset piece and move the rear crossmember back a couple inches. This will allow me to place the transmission lower. Plan to put the. Battery next to the transmission. c89cae006f5c392c5983a0bf32cdd206.jpgde2627f0dd6cbcf721f808cfd4fec660.jpg76a93a789d042fd231eaa9fb65ec2d6f.jpg9dba28442f714fc50d0b27a1196c6f68.jpg
  • Traill95 said thank you
#34 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,289 Thanks
  • 1,935 posts
Posted April 30, 2016 - 02:18 PM
That's looking good.
I was going to question the engine crankshaft rotation until I went back and took another look at the orientation of the rear axle.
Edited by jdcrawler, April 30, 2016 - 02:23 PM.
#35 BowDown ONLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted May 02, 2016 - 06:58 AM
True.
I will however need to use a double-V belt and open reversing technique for the PTO. The motor is flipped in the Bolens OE setup.
Edited by BowDown, May 02, 2016 - 11:48 AM.
  • jdcrawler said thank you
#36 BowDown ONLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted May 04, 2016 - 01:14 PM
Grinder with sanding disk and a splined pulley hub... Transmission input side is done. Output side for another day.
#37 BowDown ONLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted May 04, 2016 - 01:15 PM
9529975a0f914146a96d68a8e45680c4.jpg407fab416ed4a7dc870145b445363212.jpgf91919b34001060127d1798f18999fad.jpg
#38 BowDown ONLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted May 09, 2016 - 01:32 PM
Made some good progress on the front transmission mounting plate. Still have to finish the notch and create the rear mount. Also bought a pair of front wheels. Will mount both up tomorrow.
#39 BowDown ONLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted May 09, 2016 - 01:46 PM
154f0a059aeea4225846227e1aa1adac.jpg62384438c4c92da8885f8f77b9dfb8ae.jpg697253acc6258dd227e36a684e4e1515.jpg
#40 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,289 Thanks
  • 1,935 posts
Posted May 09, 2016 - 04:44 PM
That transmission mount sure looks like it will be good and solid.
  • BowDown said thank you
#41 BowDown ONLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted May 09, 2016 - 06:55 PM
Upon further investigation it looks like I need to replace the input shaft bearing. Will also shorten the input shaft while I'm at it. 2-2-1/2" less frame length is fine with me.
#42 BowDown ONLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted May 11, 2016 - 02:27 PM
Finally got a chance to mount up the new front wheels! Me likey
#43 BowDown ONLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted May 11, 2016 - 02:28 PM
f33920e8f7f010726d529074d5d63778.jpg3de1c2774d08551130fe03f452555137.jpg4bf3eb2f0168dda06219a66c6479da51.jpg
  • Traill95 and Newpaws493 have said thanks
#44 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted May 11, 2016 - 08:44 PM
hope you put a bearing on the front of that tran shaft for support.
#45 BowDown ONLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted May 11, 2016 - 09:47 PM
Lol answers my questions then... I was planning to pull the bushing back off again and shorten the input shaft. Also was going to look into the bearing thing. Seemed like there was some play on the shaft. Must be that there is no bearing eh?
