Pegs mounted, and gas tank has been pulled today for finishing work.
Edited by BowDown, October 03, 2017 - 01:25 PM.
Posted October 04, 2017 - 10:08 AM
Niiiiiiice!
Posted October 05, 2017 - 01:19 PM
Posted October 05, 2017 - 08:27 PM
Are you sure the bracing is adequate?
The filler neck is cool as heck.
Posted October 06, 2017 - 06:47 AM
Very true! We don't have much material here that's under 1/4" thick! Going to make for a heavy duty tractor. LOL. I over build everything anyway... going to be a double-edge sward.
Posted October 06, 2017 - 08:10 AM
Ahhhhh, ok, in my mind I was thinking horizontal. You probably said something along the way, but my mind gets distracted easy. Happens with shiny things a lot.
Posted October 06, 2017 - 08:11 AM
That looks really great but I'm a little surprised that you didn't put the fill cap right on top of the tank ?
Posted October 06, 2017 - 08:22 AM
Well the tank once fully mounted will live in the grill area. If I put the filler cap on the top of the tank I would of had to bore a hole into the cast iron grill.
I have a fuel level sender unit inside the tank from the top down now.. even though it's only 1 gallon I figured it would be neat to have a fuel level gauge. LOL.
Posted October 06, 2017 - 07:51 PM
Okay .. that makes sense and having a gas gauge is a good idea too.
Posted October 07, 2017 - 07:01 PM
Edited by jabelman, October 07, 2017 - 07:11 PM.
Posted October 07, 2017 - 10:05 PM
might want contact this dude, look at photo 9 in his ad, kinda looks like what your building https://swmi.craigsl...6310920101.html
Posted October 10, 2017 - 01:44 PM
Pressure tested the tank today.. I think it tested damn well! There was a pin hole in the weld on the top of the tank.. I sealed that with a tack weld. The only other slow leak is around the gasket for the sending unit.. The gasket is just on there dry, and I leveled that location with a 4" angle grinder... So I'll just take a bit more time with something larger format, and use some sealant on the sending unit.. But holding everything together with 10-15psi was a nice relief.
Posted October 19, 2017 - 01:12 PM
