Panzer T70 Resto-Mod
340 replies to this topic
#271 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted July 15, 2017 - 04:42 PM
Picked up some paint for the wheels , steering wheel spokes, and seat. Little ahead of myself but what the heck.
  • KennyP, tiretrx, 29 Chev and 1 other said thanks
#272 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted July 18, 2017 - 01:13 PM
Revised the steering idler mounts. Now it's all attached to the steering support structure. Also 100% symmetrical.
Now I also have 2 points of tension/alignment. Cables are good and tight and moving smooth.
My order of shoulder bolts came in today but I didn't get time to swap out the full threaded bolts.. Should give me a nice smooth movement after the swap.
Will cut off the old bracket tomorrow.
1ee7e537d580b844b6e14f93bcef3ac5.jpge621bf7f25bb5726256a108f6c068d00.jpga5eceb381fe9c4b81e1ec4587aff8509.jpg
Edited by BowDown, July 18, 2017 - 01:16 PM.
  • Chris11, KennyP, tiretrx and 2 others have said thanks
#273 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted July 20, 2017 - 01:31 PM
Good progress on the drive belt tensioner setup. Made the shim block and welded some nuts inside the tube for the tensioner to bolt to. Measured for a belt length. Also replaced the idler pulley fastener with a longer bolt that will give me a pull point for the lever actuated clutch. :)
6df2ad4084719f5927971cfa957a620d.jpga48455402fbc581ffffcdb5f5dc0259f.jpg49a0361fe2b310b6c4e3777cfae69a85.jpg
  • Alc, Chris11, KennyP and 2 others have said thanks
#274 tiretrx OFFLINE
tiretrx
  • 2308 Thanks
  • 1238 posts
Posted July 20, 2017 - 01:49 PM
Nice work, looks clean :thumbs:
  • BowDown said thank you
#275 KennyP OFFLINE
  • 52566 Thanks
  • 53108 posts
Posted July 20, 2017 - 06:35 PM
Outta work!
#276 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted July 20, 2017 - 07:01 PM
One of the two should fit!
  • KennyP, tiretrx and Clint have said thanks
#277 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1894 Thanks
  • 2359 posts
Posted July 21, 2017 - 01:48 PM
Great to see clean work, keep up the great job.
#278 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted July 22, 2017 - 02:28 PM
Worked in the tractor some today. Sucks my bolens rear wheels will not work. The offset is way off in both orientations! What rear wheels have people been using?
#279 Chris11 OFFLINE
Chris11
    old Member
  • 1730 Thanks
  • 1007 posts
Posted July 23, 2017 - 06:15 AM
I got a set of wheels from miller tire. that you weld the center in yourself any off set you want. on my t70 I drilled out the weld and changed offset to go around drums.
  • Alc and BowDown have said thanks
#280 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted July 23, 2017 - 06:16 AM
I pondered drilling the weld and changing the offset... prbly the best move. Thanks!
  • Chris11 said thank you
#281 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted July 23, 2017 - 10:15 AM
Ironically neither fit. Lol. Too long. Luckily I had some misordered belts in the shop that did. A25 works well. I need to tweak the tensioner location a bit more then finish weld it down.
Next up will be making the clevis piece to accept the cable and cable mounting bracket. Then I should hopefully have a clutch setup to test.
  • KennyP, tiretrx and Mark 149 J. have said thanks
#282 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 5915 Thanks
  • 2223 posts
Posted July 25, 2017 - 10:14 AM
I have enjoyed following your different designs for the steering.
Being a fabricator myself, I understand the thought process of trying one thing after another until you finally figure out something that works.
Then you sit back and say to your self " Dummy ... why didn't I just do that in the first place ? "
  • KennyP, tiretrx, BowDown and 1 other said thanks
#283 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted July 25, 2017 - 10:17 AM
Very true.. most of it was just the stubbornness in wanting to keep the OE center pull setup, and the car-like steering wheel angle.
#284 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted September 16, 2017 - 09:36 AM
I haven't had much time to work on it...but I did get the drive clutch setup done, final chain setup installed and aligned, and just need to weld in the battery hold downs that I fabbed up. She's really coming along now!
Hopefully get the gas tank sealed and then some wiring and try out the driveline!
7bdcf21b5da975cb5606e9917e560860.jpg7d313750b7aa0546021fcf66132469c3.jpga4194c181276d8070fbec03dd6e7d774.jpgc1e20b4465422a2cabdc7f85e5813c13.jpg
  • Alc, KennyP, Cat385B and 3 others have said thanks
#285 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 4093 Thanks
  • 2145 posts
Posted September 16, 2017 - 04:12 PM
Good to see that your still working on the project!
