I have a pair of Bolens rear wheels that I need to redrill to the Panzer pattern.. then some 10" wide ag tires will go on those. The fronts are pretty much what it is now... minus maybe going with a stiffer walled tire.
Panzer T70 Resto-Mod
#256
OFFLINE
Posted April 06, 2017 - 07:42 AM
- KennyP and tiretrx have said thanks
#257
OFFLINE
Posted April 06, 2017 - 10:09 AM
- tiretrx, Newpaws493 and Mark 149 J. have said thanks
#258
OFFLINE
Posted April 06, 2017 - 10:37 AM
Maybe the other two gears "rubbed together" in shipping and the little one wasnt in there when they boxed them up
- BowDown said thank you
#260
OFFLINE
Posted April 06, 2017 - 02:02 PM
Looks good, any shaft support?
#261
OFFLINE
Posted April 06, 2017 - 02:28 PM
Will be coming up for sure.
#262
OFFLINE
Posted April 14, 2017 - 01:37 PM
- KennyP, Newpaws493 and Mark 149 J. have said thanks
#263
OFFLINE
Posted July 01, 2017 - 10:25 AM
I just want to get past this. The fuel tank has been fabricated and fuel sensing unit installed. She's almost ready to work on drive belt tensioning.
- Chris11, KennyP, tiretrx and 3 others have said thanks
#264
OFFLINE
Posted July 06, 2017 - 07:08 AM
I think it'll work! Some minor washer shimming and lock nuts instead of regular and it'll do the trick! Also have to put some heatshrink on the cable where I had attached the ends.
Edited by BowDown, July 06, 2017 - 10:54 AM.
- jhn9840, tiretrx and 29 Chev have said thanks
#265
OFFLINE
Posted July 06, 2017 - 10:56 AM
Any plans for shrouding the spool up top?
- Mark 149 J. said thank you
#266
OFFLINE
Posted July 06, 2017 - 11:00 AM
For sure... I have a tachometer, fuel level gauge, and oil pressure gauge to install somewhere.. so I was thinking of building a gauge pod there to serve double-duty. Just wanted to prove the design first.
I also plan on shrouding the cables once they leave the rectangular box tubing portion of the frame.
- tiretrx and Mark 149 J. have said thanks
#267
OFFLINE
Posted July 11, 2017 - 06:23 PM
- tiretrx, 29 Chev and Mark 149 J. have said thanks
#268
OFFLINE
Posted July 13, 2017 - 01:13 PM
#269
OFFLINE
Posted July 14, 2017 - 01:06 PM
Will swap threaded bolts for shoulder bolts on final assembly. For now cables are just sliding in the pulleys or some are left a little loose.
- KennyP, tiretrx, 29 Chev and 1 other said thanks
#270
OFFLINE
Posted July 14, 2017 - 02:06 PM
Nice. Glad things worked out well with the steering
- BowDown and Mark 149 J. have said thanks
