Panzer T70 Resto-Mod
340 replies to this topic
#181 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted January 14, 2017 - 10:11 AM
That may be an option. I'm going to double check the rotation of the 90deg gear box shown in the pictures. If that works out I may end up with a power king style steering system.
#182 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22228 Thanks
  • 7350 posts
Posted January 14, 2017 - 10:17 AM
One other option might be to use what you have and use a relay rod over to a rock shaft located on the right and then run a short drag link from the rock shaft to the Bolens front end as I think that would have the wheels steering in the correct direction - however that may get complicated to get enough movement without things binding - best to keep it as simple as possible - good luck.
  • BowDown said thank you
#183 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted January 14, 2017 - 10:30 AM
The further I get into the build the more I should of just started with a power king. Hahah. Seems like I'm getting closer to one minus hydraulics.
#184 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Of course getting a power king for 200$ is not possible. Lol.
Edited by BowDown, January 14, 2017 - 10:31 AM.
#185 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22228 Thanks
  • 7350 posts
Posted January 14, 2017 - 03:28 PM
Hindsight is usually 20/20 but just think of the fun you are having.
#186 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted January 16, 2017 - 04:35 PM
Well it looks like the best solution is going to be building myself a steering rack and pinion. I have some of the gear track stock and one of the pinion gears for a 3/4" input shaft. See how it goes! Fab to start tomorrow during lunch.
  • KennyP, tiretrx and 29 Chev have said thanks
#187 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted January 23, 2017 - 11:31 AM
Parts are here. More to come!
  • Alc, KennyP, tiretrx and 3 others have said thanks
#188 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted January 23, 2017 - 02:02 PM
Should work out fairly well. Not a whole lot of time to work today but happy with the pieces.
  • Alc, KennyP, Newpaws493 and 2 others have said thanks
#189 tiretrx OFFLINE
tiretrx
  • 2308 Thanks
  • 1238 posts
Posted January 23, 2017 - 02:52 PM
Interesting. Look forward to the install :thumbs:
#190 KennyP OFFLINE
  • 52655 Thanks
  • 53133 posts
Posted January 23, 2017 - 04:15 PM
I have just the hydraulic motor to make that work real nice!
#191 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted January 23, 2017 - 04:20 PM
Lol. Maybe another time. No hydraulics at this point planned.
#192 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22228 Thanks
  • 7350 posts
Posted January 23, 2017 - 04:58 PM
Looks good - I assume the bearing is self aligning so are you planning on putting a bushing on the other side to keep the gear parallel to the track?
#193 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted January 23, 2017 - 05:01 PM
Yes sir I will be taking a piece of 1/2" thick mild steel plate and bore a 3/8" or so deep by 3/4" diameter relief to act as a shaft support on the back side.
  • Alc, KennyP and 29 Chev have said thanks
#194 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted January 27, 2017 - 02:27 PM
Some more steering box work. I need to mount the bearing and do some mill work on the gear rack to accept rod ends. Also bore a hole through the pinion gear collar and shaft to insert a roll pin. Then create some end caps. Thinking it may hang off the stock steering vertical stem. In theory anyway!
bf5faf305c4ac6552d6d712c29271cef.jpg98a910a825b22d77bdec006fd1894b7d.jpga230db76883c71713c035ca2c46d5999.jpg
Edited by BowDown, January 27, 2017 - 02:33 PM.
  • Alc, KennyP, stiemmy and 2 others have said thanks
#195 tiretrx OFFLINE
tiretrx
  • 2308 Thanks
  • 1238 posts
Posted January 27, 2017 - 03:24 PM
Coming along well :thumbs:
