It's a Kohler Magnum 18.
Panzer T70 Resto-Mod
#166
OFFLINE
Posted January 07, 2017 - 06:39 PM
- BowDown said thank you
#167
OFFLINE
Posted January 07, 2017 - 06:40 PM
Oh nice. Sometimes they are tough to tell the diff.
#168
OFFLINE
Posted January 07, 2017 - 07:02 PM
So out of curiosity without derailing this thread.. why such a large hood area if the motor hangs off the back?
#169
OFFLINE
Posted January 07, 2017 - 08:00 PM
The tractor was built to the rough size specs of a 24G Gravely. On that tractor, the hood area houses the large gas tank, hydraulics tank, pump and battery. On this it houses the gas tank, battery and steering linkage. It was worked backwards from the aesthetics more than anything.
- Alc and BowDown have said thanks
#170
OFFLINE
Posted January 08, 2017 - 06:00 PM
Not a bad couple hours. I cut off the old brackets and inlet sleeves on the mufflers. Then welded in new inlets. I then tacked the 2 pieces of the stretched u-bend together and then mocked them up. May end up tweaking the down angle a bit but it's damn close. Also cut some plate for new 2 point muffler to frame mounts.
Edited by BowDown, January 09, 2017 - 08:09 AM.
- KennyP, Cat385B, tiretrx and 2 others have said thanks
#171
ONLINE
Posted January 08, 2017 - 06:18 PM
I want to hear this run. Put the mike right down there at the end of the muffler! Those are some cool mufflers!
- tiretrx, BowDown and Mark 149 J. have said thanks
#172
OFFLINE
Posted January 08, 2017 - 06:23 PM
Looks nice - are you going to use mechanical linkage or hydraulic cylinder for steering? The reason I ask is that the right hand muffle may be in the road of a drag link if you are going with mechanical.
#173
OFFLINE
Posted January 08, 2017 - 06:32 PM
HD screaming eagle mufflers.
#174
OFFLINE
Posted January 08, 2017 - 06:33 PM
It's not as close as it looks. Lol.
But to answer it will be the mechanical center steer setup like the panzer had oe.
- Cat385B and 29 Chev have said thanks
#175
OFFLINE
Posted January 09, 2017 - 08:50 AM
That's suh-weeeet! Bet it will sound as good as it looks, nice work
#176
OFFLINE
Posted January 09, 2017 - 09:15 AM
Thanks man. I'm going to take a cutoff wheel to the top 90 joint and allow the pipes to drop straight down instead of tip out towards the front. The U-bend is actually a perfect 90/90, but the manifold outlet sends the pipes up at a couple degree angle...
- KennyP said thank you
#177
OFFLINE
Posted January 13, 2017 - 04:41 PM
- Mark 149 J. said thank you
#178
OFFLINE
Posted January 13, 2017 - 04:57 PM
Looking at the steering setup I am thinking that when you turn the steering wheel to the left the front wheels are going to turn to the right or am I missing something?
#179
OFFLINE
Posted January 13, 2017 - 05:12 PM
Hmm. May be onto something...
#180
OFFLINE
Posted January 13, 2017 - 05:30 PM
The reason I asked was my dad encountered a steering set up that he thought would work perfectly to update a 29 Chevrolet car many years ago - got it all hooked up and found out that when he turned the wheel one way the car would go in the opposite direction - very confusing. He ended up using another steering box set up to have it work the correct way and it was a learning experience for me. Can you rotate the bottom gear 180 degrees and then make a new mount for the shaft - just a suggestion?
- KennyP, tiretrx, Newpaws493 and 1 other said thanks
