MW Gilson hydro service point?
2 replies to this topic
#1 ACmowerguy OFFLINE
ACmowerguy
  • 384 Thanks
  • 354 posts
Posted March 06, 2016 - 10:07 PM
I picked up a 1973 and 1974 MW by Gilson tractors with the Vickers hydrostat. I downloaded a manual and it states the transmission should not need service for the life of the tractor and if it leaks take it to the MW service center, HA, good luck with that. It looks like there is a plug above the filter. I suppose this is where you fill it? This Vickers has the usual leaking pintle shaft.
Thank You.
Chris
#2 gopher OFFLINE
gopher
  • 749 Thanks
  • 752 posts
Posted March 06, 2016 - 10:54 PM
That is the fill and level. You pull the pipe and filter up till filter touches bottom of trans- axle the plug is fluid level.
  • ACmowerguy said thank you
#3 ACmowerguy OFFLINE
ACmowerguy
  • 384 Thanks
  • 354 posts
Posted March 07, 2016 - 12:06 AM
Thank You.  I'll degrease it and check that out.
