Aftermarket Oil Control Ring Install Problem
2 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,447 Thanks
  • 3,057 posts
Posted March 06, 2016 - 03:51 PM
It isn't made like the Briggs and Stratton OEM ring. I don't know how to install it two thin ones and a spacer.
#2 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,458 Thanks
  • 5,765 posts
Posted March 06, 2016 - 03:58 PM
Install the spacer first and be sure the ends of it aren't overlapping.  If the ring has a mark on it that side goes up. No mark makes no difference.  (Same for all rings)
Then install the bottom oil ring below the spacer.  Make sure the end gap is at least 90° away from the spacer.
Then the top oil ring goes above he spacer ring..  Make sure the end gap is at least 90° away from the other ring / spacer.
Putting those things together can be a PITA but with patience it can be done..
Edited by WNYTractorTinkerer, March 06, 2016 - 04:00 PM.
  • DougT, limebuzz, Alc and 3 others have said thanks
#3 KennyP ONLINE
  • 38,302 Thanks
  • 45,899 posts
Posted March 06, 2016 - 05:29 PM
Been using that type of oil rings for years. Dave is correct with his advice!
  • boyscout862 and bbuckler have said thanks
