Bolens #2 is home!
24 replies to this topic
#16 wurzel OFFLINE
wurzel
  • 120 Thanks
  • 104 posts
Posted March 07, 2016 - 10:59 AM
maybe theres no oil in the hydro
nice find anyway
#17 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted March 11, 2016 - 11:15 AM
Well I finally got to tear into the H14 today, just a little bit though. I pulled the seat pan off and checked everything out a little bit. Looks fairly normal, grease everywhere, but the lift cylinder is caked with a ton of grease, and I can move it by hand but then it pops back when I release. Should it be able to do that? Also, there's like a tab cut out on the back of the seat pan, but it doesn't look hacked. It's either factory, or whoever cut it did a pretty good job!
Edited by gardentractornut, March 11, 2016 - 11:16 AM.
  • Bolens 1000 and LPBolens have said thanks
#18 Husky OFFLINE
Husky
  • 1,269 Thanks
  • 1,119 posts
Posted March 11, 2016 - 12:03 PM
That tab is factory.  A user could punch it out if there was something on the back like a hitch that raised up. I had a few with the tab and some without.
  • blackjackjakexxix and Sawdust have said thanks
#19 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted March 28, 2016 - 03:26 PM
Well today was finally the day. I ripped the TRA-12D from the 1254 and dropped it in the H14. For some reason I could only get 3 bolts in but that's fine, it worked pretty good. The hydro works! Yay! I know pretty much nothing about them, so I am extremely glad that I don't have to tear it down. The hydro lift works too, although the cylinder leaks a bit. I did get a short video of the lift working. Don't mind my makeshift hang-n-haul, it looks like crap!
I had an extra half hour a few weeks ago so I fried it together with some scraps. It'll work till I make a nice one. I'm going to put the video on youtube later.
  • Bolens 1000, blackjackjakexxix, Rock farmer and 3 others have said thanks
#20 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 8,737 Thanks
  • 2,877 posts
Posted March 28, 2016 - 04:02 PM
Glad you got it swapped over and things are working.
#21 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,178 Thanks
  • 697 posts
Posted March 29, 2016 - 05:15 PM
Are you planning on keeping the Wisconsin in the H14, or did you just swap it in to test the hydro drive?
Jim
#22 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted March 29, 2016 - 09:47 PM
Jim
Just testing the hydro. It's back in the 1254 again now.
  • CanadianHobbyFarmer said thank you
#23 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,178 Thanks
  • 697 posts
Posted March 30, 2016 - 04:39 PM
Are you looking for a new engine for the H-14, or are you going to try to get the original back up and running? I recently picked up a second 1054 with a Honda swapped into it. I did get the original Wisconsin with it as well and I am hoping to get it running and put it back in. So far I know I need a head gasket and need to remove and replace a broken head bolt. The bolt is my own fault for not just letting it soak in PB blaster for a couple of days. The piece that is still in the block is soaking now.
Jim
#24 Sawdust ONLINE
Sawdust
  • 5,677 Thanks
  • 3,379 posts
Posted March 30, 2016 - 06:11 PM
Definitely a nice deal like mentioned well worth the effort to get it back up & running. I have an H16 & love it. Mine ran well but the rear pan looked like it was on a bumper car at the local fair, the side tube covers were missing but I found them on ebay & did some body work on it...real happy with it. Keep us up to date.
#25 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted March 30, 2016 - 09:11 PM
The seat pan is a little bent outta shape on this one too, but not horrible. I sure will!
Jim
Right now I think I have a deal nailed down on a HH140 with a stripped out spark plug hole. We'll see where it goes...
