Dana 20 rear axle used under Deere,Ariens,and others
leaking pinion
6 replies to this topic
#1 rustyoldjunk ONLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,401 Thanks
  • 1,227 posts
Posted March 04, 2016 - 07:11 PM
The Dana 20 axle was used under the late JD 140's and early 300 series,early New Holland,Ariens for decades,and other brands. I have a Dana 20 under a Roper 18T hydro that has a leaking pinion seal. Not where the hydro bolts to the rear and drives off but below that,the actual pinion. It has sat a long time. I went thru the hydro got it all back together and got the rearend and hydro back under the tractor. This evening I started to fill it with fluid and it came pouring back out around the pinion. Has anyone replaced that seal before ? Where did you get a seal ? Can it be replaced from the outside ? I don't want to pull the rearend back out again if I can help it.
#2 rustyoldjunk ONLINE
rustyoldjunk
  • 2,401 Thanks
  • 1,227 posts
Posted March 04, 2016 - 07:43 PM
Well,I think I figured it out. It is missing a soft welch plug. I should have noticed that. Now,where do I get one ?
#3 JDBrian OFFLINE
  • 9,591 Thanks
Posted March 05, 2016 - 06:13 AM
I'm not sure where to find that plug. Have you checked the JD parts site to see if it is listed as a part there. Many parts are still available. You might also try Dana distributers. If you can find a dealer with an experienced parts person they might be able to get the part. That's a strong rear end. I have a JD 314 and a 317 with that setup.
  • rustyoldjunk said thank you
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,169 Thanks
  • 5,762 posts
Posted March 05, 2016 - 08:07 AM
What is the measurement on the plug?
  • rustyoldjunk and have said thanks
#5 JDBrian OFFLINE
  • 9,591 Thanks
Posted March 07, 2016 - 08:50 AM
Just a detail, but I believe the JD 120 also used the Dana 20 rear end. I have read that the Ariens setup is prone to breaking the welds where the Rear end mounts to the frame. Not sure if other applications have had this issue.
#6 rustyoldjunk ONLINE
rustyoldjunk
  • 2,401 Thanks
  • 1,227 posts
Posted March 13, 2016 - 01:40 AM
That's true on both counts Brian,I did leave out the 120 and I have broken the rear mounts on a Ariens. Of course I had a 54 inch plow on the front,a 5 ft CAT.0 3 point grader on the rear loaded 10.50 ags and 100 pound wheel weights on it ! It was a pushing,grading machine though...... :D
#7 rustyoldjunk ONLINE
rustyoldjunk
  • 2,401 Thanks
  • 1,227 posts
Posted March 13, 2016 - 01:43 AM
Turns out its a 2 1/2 inch plug. I went to Deere and got one for $5.
Now the problem is no flow out of the pump. I started a thread in the hydraulics subforum.
  • JDBrian said thank you
