New member getting ready for spring
13 replies to this topic
#1 tractor buddy OFFLINE
tractor buddy
  • 3 Thanks
  • 56 posts
Posted May 01, 2011 - 01:30 PM
have a 330 made into a 332 I have not been taken care of it very well.
I can't find the ser # anywhere. I traded it for a 5 yr old 318 back in 1979-1980 it had .2 hrs on it. it now has 323 hrs. In 38 year I have kept my filters very clean. I am now putting on my 3rd air filter. Battery not charging I don't know why.
Good to be here
Bernie
Edited by tractor buddy, May 01, 2011 - 01:40 PM.
  • middleageddeere said thank you
#2 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted May 01, 2011 - 02:39 PM
Welcome to GTtalk
#3 NUTNDUN OFFLINE
  • 10,352 Thanks
Posted May 01, 2011 - 03:25 PM
Welcome to GTtalk. Hope you enjoy the place and find the information you are looking for.
Have you checked the voltage coming out of the stator? Or the regulator?
#4 MH81 OFFLINE
  • 29,979 Thanks
Posted May 01, 2011 - 03:40 PM
:welcome: to GTTalk! Hope you find your charging problem soon.
Glad you found us.
#5 mjodrey OFFLINE
Posted May 01, 2011 - 04:00 PM
Bernie,:welcometogttalk:
Glad to have you with us.
#6 caseguy OFFLINE
  • 1,629 Thanks
Posted May 01, 2011 - 08:55 PM
:wave: tractor buddy Welcome to GTTalk! It very nice to have you with us! I don't know very much about the JD's, but there are several on here who do. I hope that you get your trouble figured out soon. In the meantime, enjoy the forum and all that it has to offer!
#7 daytime dave OFFLINE
  • 4,967 Thanks
  • 6,598 posts
Posted May 01, 2011 - 09:20 PM
Welcome Bernie, glad you are with us. Hope the problem is solved quickly.
#8 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 02, 2011 - 10:07 AM
Nice to have you here. It could be your regulator/rectifier, or the alternator itself. I would start by checking all the connections as they can get corroded over the years. Make sure you have a solid chassis ground. Check the alternator windings to make sure you have continuity. I assume your battery is OK. If you can check the AC voltage going into the regulator then that will tell you if the alternator is working.
Good luck getting it repaired.
  • tractor buddy said thank you
#9 tractor buddy OFFLINE
tractor buddy
  • 3 Thanks
  • 56 posts
Posted May 03, 2011 - 09:41 AM
Thanks Brian
It was a ground problem.DSC_4969.jpg Thought I'd try an upload.
#10 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted May 03, 2011 - 11:35 AM
Welcome aboard Bernie
Enjoy!
Be sure to take a look at our member map and feel free to add you location.
#11 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 07, 2011 - 06:37 PM
Bernie - What do you have on your 3PT hitch in the picture? Is it some sort of adapter for towing the trailer?
#12 tractor buddy OFFLINE
tractor buddy
  • 3 Thanks
  • 56 posts
Posted May 08, 2011 - 09:23 PM
Brian - It's a scoop tote. scoop by backing up lift with the hydrolysis pull cord to dump works great. do you want more pic's ?
#13 broken2 OFFLINE
broken2
  • 280 Thanks
  • 425 posts
Posted May 08, 2011 - 10:02 PM
Definitely more picks of the scoop!
#14 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 09, 2011 - 10:19 AM
Yes please, let us see more pictures. I have a 24" worksaver 3pt hitch scoop that I used as a poor mans loader when I had my x475. It looks different than the profile shot of your scoop. I have a loader on the 2320 but I still use the scoop frame with a homemade rake/scarifier to loosen up the driveway before grading it.
