HD12 Hydro Oil Cooler
14 replies to this topic
#1 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted March 04, 2016 - 10:52 AM
Anyone ever put a hydro oil cooler on a HD12? I going to take it to PA plow day in April do you think it will help. Just looking for imfo thanks
  • BosaldZego said thank you
#2 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted March 04, 2016 - 11:16 AM
It will help immensely!  I plowed with my JBI same hydro setup) and the hydro got insanely hot.  I recommend a hydro oil cooler for anything under a heavy pull such as plowing.  Just put the cooler line to pick up it's oil between the lift valve outlet and the return port in the hydro.
  • LPBolens and Alc have said thanks
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted March 04, 2016 - 11:43 AM
The difference in operating temps will surprise you
#4 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted March 04, 2016 - 01:48 PM
Is there a lot of psi. On that line? I got a oil cooler off a Case garden tractor it about 10" sq. hoses just clamp on do you think it will work? Or should I get a transmission cooler like off a pickup?
#5 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted March 04, 2016 - 01:57 PM
image.jpeg image.jpeg Case oil cooler
#6 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted March 04, 2016 - 02:36 PM
No pressure except what the fittings may cause. That cooler would work fine long as you can attach it.
  • Jake said thank you
#7 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted March 04, 2016 - 03:07 PM
#8 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted March 06, 2016 - 03:28 PM
One more ? Witch line is the return line thanks againattachicon.gifimage.jpegattachicon.gifimage.jpeg
Pretty sure it's the one on the side of the pump housing, but I'll check one of mine to be sure.
  • Jake and KennyP have said thanks
#9 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted March 06, 2016 - 04:24 PM
If the pic wasn't cropped so close, we could figure it out easier. I have no knowledge of Bolens to find that manual!
#10 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted March 06, 2016 - 06:05 PM
Yes, return port is the side port, where fitting S1801 is in the diagram.
#11 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted March 06, 2016 - 06:29 PM
Thanks fo all the help
  • olcowhand said thank you
#12 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted March 06, 2016 - 10:51 PM
What will it help immensely? Pulling power or longevity or what are you referring too?
#13 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted March 13, 2016 - 11:43 AM
#14 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted March 13, 2016 - 12:15 PM
That should help a lot.  A fan would be much better, but forward movement plus air flow created by the flywheel fan will boost cooling.
  • LPBolens and Jake have said thanks
#15 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted March 13, 2016 - 12:18 PM
It will improve life of the hydrostat by decreasing wear, limiting oil breakdown, and pulling power by decreasing the thinning level of the oil.  Under heavy use, the hydro can become extremely hot.
  • LPBolens and SupplySergeant have said thanks
