5 volts at the spark plug... huh?
No luck getting the 1250 running
#46
OFFLINE
Posted March 03, 2016 - 08:02 PM
- accidentalchild said thank you
#47
OFFLINE
Posted March 03, 2016 - 08:07 PM
#48
OFFLINE
Posted March 03, 2016 - 08:16 PM
I just hooked up my voltmeter directly to the spark plug wire after disconnecting it from the spark plug. I used an alligator clip to attach it. I would then turn the key as if to start it and see how many volts there were. Since I have a good running s14d I tried the same test with it. The 1250 was getting 5 volts and less and the 1476 was getting consistently just under 12v.5 volts at the spark plug... huh?
#49
OFFLINE
Posted March 03, 2016 - 08:26 PM
#50
OFFLINE
Posted March 03, 2016 - 08:58 PM
Disconnect the wire/s going to the points from the coil negative side--- then use the meter and measure from the + wire on the coil (still connected) RED lead on meter to + black lead to ground Should read 12 v approx. with switch on....if it does Good Next step remove plug and make sure it is grounded to the head away from the spark plug hole and it is still connected to the coil---- take a jumper wire and short the Negative side of the coil to the head (Tap it to ground with switch on) every time it makes and breaks connection you should see the plug spark if it does Good. Now you will need to check the points.
- 1967bolens collector, blackjackjakexxix and accidentalchild have said thanks
#51
OFFLINE
Posted March 03, 2016 - 09:34 PM
- blackjackjakexxix and accidentalchild have said thanks
#52
OFFLINE
Posted March 03, 2016 - 09:39 PM
thanks , will check that out.Disconnect the wire/s going to the points from the coil negative side--- then use the meter and measure from the + wire on the coil (still connected) RED lead on meter to + black lead to ground Should read 12 v approx. with switch on....if it does Good Next step remove plug and make sure it is grounded to the head away from the spark plug hole and it is still connected to the coil---- take a jumper wire and short the Negative side of the coil to the head (Tap it to ground with switch on) every time it makes and breaks connection you should see the plug spark if it does Good. Now you will need to check the points.
#53
OFFLINE
Posted March 03, 2016 - 09:51 PM
maybe that Ballast resistor is no good or the Coil has an Internal resistor? If the coil has an internal resistor you don't need the Ballast resistor.It will not spark with Both.It should say on the side of the coil if it has an internal resistor.
Check and see if there is 12v going into the Ballast resistor.You might be OK up to that point.That will eliminate most of the wiring as the problem if it does.
Edited by EricFromPa, March 03, 2016 - 09:52 PM.
- blackjackjakexxix, accidentalchild and Paulgo have said thanks
#54
OFFLINE
Posted March 04, 2016 - 01:23 AM
The Wisconsin singles are notorious for cranking over slowly. When I first got one, I thought it could never start cranking that slowly. But it did, and does.
This may not work for you, but when I had a weak, intermittent spark on a 1250 that had been sitting for a long time, and the tractor would not start, it turned out to be oil varnish built up under the points so they could not ground properly. Once I cleaned up the points box, and re-installed the points, the tractor fired up and ran fine.
#55
OFFLINE
#56
OFFLINE
#57
OFFLINE
Posted March 05, 2016 - 04:35 PM
#58
ONLINE
Posted March 05, 2016 - 07:54 PM
It appears you have two red wires attached to the + side of the coil. .....One comes from the ballast resistor. .....Where does the other red wire go?
The blue or black wire attached to the neg (-) side of the coil is attached where? ....It should be attached to the external stud at the breaker box.
#59
OFFLINE
Posted March 05, 2016 - 07:56 PM
the blue wire is attached to the stud on the breaker box the second red wire goes to the fuel pump.It appears you have two red wires attached to the + side of the coil. .....One comes from the ballast resistor. .....Where does the other red wire go?
- Bruce Dorsi said thank you
