No luck getting the 1250 running
137 replies to this topic
#136 Rock farmer ONLINE
Rock farmer
  • 1537 Thanks
  • 1433 posts
Posted March 30, 2016 - 01:53 AM
I would suspect you've got bad bearings in it.
It should have a bearing or bushing on each end of the armature shaft.
Perhaps it even has small flip top ports for adding oil at those points.
Some times they get filled with water and rust inside.
They can be rebuilt.
Joe
  • TomLGT195 and accidentalchild have said thanks
#137 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5121 Thanks
  • 2911 posts
Posted March 30, 2016 - 08:24 AM
Any idea why my starter generator is smoking real bad and then stops spinning? The engine then Boggs down and dies.
If I remember correctly there should only be two wires connected to the starter/generator.  ...Where is the 3rd wire connected to?
  • accidentalchild said thank you
#138 accidentalchild OFFLINE
accidentalchild
  • 382 Thanks
  • 463 posts
Posted March 31, 2016 - 02:35 PM
The wiring is correct as far as I can tell from the wiring diagram I have. The starter gen does have bearings on either end of the armature. I am betting that the tapped out holes on the starter gen should be filled with a set screw or something? It came with four or so holes like the one in the picture I will post. I do see areas where there is a screw for adding lubricant if that is what those are fore. What type of lubricant do they use in these? This unit I bought new so hopefully it's not ruined by my inexperience, if so oh well lesson learned. It still runs well until it heats up and then stops spinning and the engine dies.
