Honing with Crankshaft in
4 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,484 Thanks
  • 3,074 posts
Posted March 03, 2016 - 01:48 PM
After fighting with the timing on the other B&S 320000. I was wondering if I could hone the other one to get the cross hatch pattern without take the crankshaft out ?
#2 olcowhand ONLINE
  • 41,287 Thanks
  • 31,454 posts
Posted March 03, 2016 - 01:53 PM
I hone with crank in all the time.  Just be sure to give it a good cleaning afterwards.  I give then a soapy hot water was a couple times, rinse well, then blow dry with compressed air.  Follow with a coating of spray can lubricant over the internals to prevent rust before assembly.
  • TomLGT195 and bbuckler have said thanks
#3 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted March 03, 2016 - 07:12 PM
Ya sure but cover the crank journal in heavy grease and spray carb cleaner or brake cleaner down the bore from the crank side and whipe out with a clean White cotton cloth (old T-Shirt) till the cloth comes out Clean.
Don't forget after installing the rod and piston to turn the engine upside down and dump some Oil all over everything.
I forgot to oil up a Kohler that I put new rod and rings in.Fired it up and it run good for about 10-15 seconds then heard the Loud Squeal.The Camshaft seized to the Cam pin and spun in the block because there was no oil on the darn thing yet.Luckily I had a used cam and pin to put back in it.Luckily I caught it before it snapped and Didn't hurt the holes for the cam pin.Still had to use a punch to install the new Pin so it was still tight.
Edited by EricFromPa, March 03, 2016 - 07:14 PM.
#4 bbuckler ONLINE
bbuckler
  • 3,484 Thanks
  • 3,074 posts
Posted March 06, 2016 - 01:53 PM
Does this look good to you all ? First time honing a engine.
#5 olcowhand ONLINE
  • 41,287 Thanks
  • 31,454 posts
Posted March 06, 2016 - 03:25 PM
Looks like you may not have enough cross-hatch.  You want the lines to intersect forming a 60 degree angle to each side.  You have to run the hone slowly while pulling hone in & out rather fast.
  • limebuzz, MH81, KennyP and 2 others have said thanks
