Intermittent electrical problem
11 replies to this topic
#1 JCV OFFLINE
JCV
  • 5 posts
Posted March 03, 2016 - 11:55 AM
I have a 25 year old G-series tractor with a Kohler Magnum 12 engine.  Sometimes it cranks fine, others, I turn the key and nothing happens-- I have to bypass the solenoid with a screwdriver.
Any suggestions?
Many thanks.
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted March 03, 2016 - 12:02 PM
:welcometogttalk: Check the switch. :camera:
  • JCV said thank you
#3 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,450 Thanks
  • 4,571 posts
Posted March 03, 2016 - 12:32 PM
Went through the same thing with another GT. Soulution was to clean all the connections on the ignition switch, safety switches, and battery terminals.
#4 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,103 Thanks
  • 10,178 posts
Posted March 03, 2016 - 12:37 PM
Did anyone mention the ignition switch? When you go to Napa to get a new one, take the old one along. There are a thousand models of them.
#5 DougT ONLINE
DougT
    Dog Approved
  • 7,111 Thanks
  • 5,076 posts
Posted March 03, 2016 - 12:50 PM
When you say jump the solenoid, are you putting power on the small terminal or do you have to jump the 2 big terminals? Take a test light and start testing the circuit to see where you lose the voltage from the switch to the small terminal on the solenoid. It could even be something like a clutch switch or another safety.
#6 HDWildBill OFFLINE
  • 8,984 Thanks
Posted March 03, 2016 - 01:22 PM
I just dragged a tractor from it's grave it has been sitting in for the past 2 years or so.  When I went to start it with the ignition switch I got nothing so I jumped between the large terminals and it turned over.  I then applied power to the small terminal through a remote switch I have.  It turned over just fine.  So after I went through the engine to check everything over and change the oil, I decided to try the ignition switch again and it worked.  It has worked since then so I'm assuming that either it had some water in one of the contacts or the solenoid was stuck.  It it happens again I'll go further.
These intermittent electrical problems will defiantly give you a few more gray hairs!
#7 devans OFFLINE
devans
  • 371 Thanks
  • 257 posts
Posted March 04, 2016 - 12:09 PM
Ignition switch is the likely problem, I've seen dozens of these posts asking the same thing and a new switch fixed it. As a matter of fact the switch in my Gravely 816 is bad, If I turn it all the way to start it doesn't work. I have to back the key up a little and it will catch.
I have a new switch for it but it will go in when I start the re-build.
  • Alc and JCV have said thanks
#8 JCV OFFLINE
JCV
  • 5 posts
Posted March 21, 2016 - 10:49 AM
Ignition switch tested out OK--working my way through safety switches.
#9 JCV OFFLINE
JCV
  • 5 posts
Posted March 21, 2016 - 10:51 AM
Just yesterday discovered that the negative battery connection was loose and cannot be tightened any further. will replace.
#10 JCV OFFLINE
JCV
  • 5 posts
Posted March 21, 2016 - 10:54 AM
Switch tested out OK-- I replaced it a few years back, but I couldn't get ir fully reconnected. I am going to disconnect, dry and add some dielectric grease.
#11 JCV OFFLINE
JCV
  • 5 posts
Posted March 21, 2016 - 10:57 AM
I was using the two big terminals. I have since used a multimeter to check voltage--ignition swich seems OK. Havent gotten back to test all of the safety switches.
#12 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,979 Thanks
  • 2,476 posts
Posted March 21, 2016 - 03:20 PM
Some solenoids require 12v + applied to the small terminal of the solenoid to activate it. (If you have this type, verify a good ground at the solenoid mounting.)
Some solenoids require 12v - applied to the small terminal of the solenoid to activate it. (Usually one of the large terminals is marked "BAT." )
Do you know which type of solenoid you have?
